Best gas in SoCal?
I have been trying the new Shell V-Power and the E500 runs better with it, especially after initial cold start in the morning. I have had a slight shudder at idle the first few seconds after a cold start in the morning with the Arco gas I have been using up to now, which I mainly bought because it was cheaper than everything else. This phenomenon could also be coming from the transmission, however, which it was a lot of people have been describing. Anyway, I wanted to get some input on what other people in SoCal gas up. What is recommendable without being to much more expensive than anything else. ( I have heard good things about Chevron, but pricing is steep!)
Thanks for your input! have a good weekend!
I never noticed how diffrent gasoline affected the car I was driving. I was always sort of partial to Chevron just because the one nearest to my house was always a few cents less than other gas stations. But when I purchased my E500 in Novemeber I started filling it up with Shell V-Power the 1st few times. I then tried a few other gas stations such as Chevron and Unocal and can say for sure the e-500 just seems to run better in Shell V-power.
Strange, but good to know I am not the only one who noticed a diffrence.
J-
In terms of the smaller "mom and pops" or independent gas station. They buy fuel from the larger "brand name" companies ship the fuel in unmarked tankers and sell them out of their own pumps. And that is pretty much how the fuel trade works.
Of course there are difference in the different octane rating. people should use the highest octane rating just because it burns cleaner. Not only does a cleaner burning engine run more efficiently, but its also safer for the environment.
I use only Chevron Gas/Diesel.
Where on Earth did you incorrectly learn that ?
What does a fuel's octane rating have to do with how cleanly it will burn?
By way of example, I used to drive a VW during my college years on the East Coast. I was a regular Shell/Mobil user and found both worked fine. On occasion, however, I was forced to use Exxon and my car's performance suffered because of it (this is 1989 through 1997 and thus, pre-ExxonMobil merger). The car would sputter and its acceleration was sluggish at best. Accordingly, I avoided Exxon (and still do) at all cost. On the other hand, I loved Sunoco's high octane blends (91/92/94 octane). They were a little pricey for a college/grad school student, but they were clearly superior to other gasolines of similar octane, in my opinion.
Research this yourself. You'll find that there are other benefits with putting isopropyl alcohol in a fuel tank every now and then. Aside from the emissions thing, it helps out with winter driving. Southern Cali doesn't get too cold to cause problematic winter driving, but it does back east and in the midwest. You see, in the winter, condensation or water in your vehicle's fuel tank or possible water contamination of the fuel you pump in can lead to hard starts and other drivability problems. Since water is heavier than gasoline, it tends to settle in the bottom of your fuel tank, where it gets sucked into the fuel lines and fuel system. If too much water contamination is present, it can freeze in the fuel lines or, since water doesn't burn very well, give your engine a severe case of the hiccups at the worst possible moment, such as when you're trying to make it across a busy intersection. To prevent this, aside from keeping the fuel tank as full as possible at all times (to help prevent condensation), using isopropyl alcohol or an equivalent content based additive will work. The isopropyl alcohol works by absorbing the water present in the fuel tank, allowing it to be carried through the fuel system and burned up with the gasoline.
I do have to agree.... I have been using MOBIL (since it's the nearest station).... and have switched to SHELL yesterday after reading this thread.... I CAN tell a difference between both stations.... my car SEEMS to run better with SHELL than with MOBIL
It's the same deal in each region of the US.
So that may explain perceived "running" differences for some cars .
For example, most of the East Coast is supplied by fuels originating from Houston refineries, delivered by Colonial Pipeline's network. http://www.colpipe.com/ab_map.asp
