P087 low fuel rail pressure 06 e320cdi
I was driving around town,was at a stop light to enter freeway and stepped on the gas, won't accelerate and ced p087 came on. Got home and next day started the engine and everything was fine until it happened again after 3 days. I noticed that it loses fuel pressure after driving around 20 to 30 miles around, get to a stop light and low fuel pressure. So what I did was when the car went into a limp mode, I turned off the engine when I got to a stop light, turn it back on, pressure came back on and car will run fine. No issues in starting the engine. Sometimes car runs fine for 2 to 3 days without losing fuel pressure. Is my fuel pump going bad?
Thanks in advance for any help or ideas what might be causing this problem
Received 1,744 Likes
1922 Ford Model T / no OBD
You might want to move the topic to diesel section for more exposure.
What's mileage? Those pumps can go for at least 1/2 million miles, so start with checking injectors for leaks.
Leak testers are easy available and I remember members building their own.
Than when ignition cycling restores the pressure - the regulator comes to mind.
w211 270 cdi w211 320 cdi
hi i have the same trouble !! all is fine the car is 100 % and when i accelerate limp mode ..same as you could you help me please what was the issue with you ? i tested the injector changed the rail pressure sensor ..and still the same trouble everything is ok and limp mode ....
thanks for reply....
no i will do and let you know
..thanks there are other things that i have to check ?
Limp mode can be triggered by multiple issues... EGR, swirl flaps on intake have caused it for me in past. Scan for codes to start with but ideally a scanner with live data capabilities will display rail pressure & injector contribution while engine is running. I do this with Star DAS but icarsoft mbII can do it too.
thanks for replying and for your attention and help :
i have egr off swirl flaps like new (changed all the collector) with scanner in live everything is ok rail pression at 1600 bar max and after time limp mode and message rail pression is to low stop the engine restart everything i ok
since 2 months im in this case and i dont know where to go ...
help please ...
help please ...
2013 ML350 Bluetec
How many miles on the injectors?
Full tank of fuel or nearly empty when the problem occurs?
What is the ambient temperature when the problem occurs?
What engine load are you seeing before it happens?
thanks for reply the car have 140 000 km (92584 miles) quarter tank or plus when the problem occur ambiant temperature 80 90 generally happen in low tr min 3000 4000 trm
thanks for your time
I had this issue on my CDI back in February on a road trip.
Come to find out it was just a bad sensor at the front of the fuel rail that just needed replaced.
Ordered it from FCP Euro for $120 and had my local Indy mechanic fix it.
No problem since.
No problem since.
it was the rail pressure sensor ? or the fuel sensor ?
Originally Posted by AmirChouaieb;[url=tel:8351819
8351819[/url]]it was the rail pressure sensor ? or the fuel sensor ?
Originally Posted by AmirChouaieb;[url=tel:8352078
8352078[/url]]i changed it but still the same...
thans for your reply and interresst
run live data with the star diagnostics. If it’s from the EGR or swirl flap device then just delete those systems.
egr deleted and swirl flap ok i tested ...i think i will also delete
have question please any relation between egr , swirlflaps with low pressure fuel on ramp ??
thanks for your time and attention .
I change injectors , fuel pump , hoses , fuel filter , check the fuel regulator valve , fuel relieve valve
and still code P0087 😶
Amir, Did you fix ?
Having similar mysterious Rail Low pressure on E320 CDI, after replacing Y74, Y94 and Rail Pressure sensor. This is all 3 rail components.
