E-Class (W211) 2003-2009
2008 E350 4matic brake caliper questions
Old Feb 9, 2020 | 05:50 PM
WarMachine1804's Avatar
08 e350 4matic
Hey so im trying to R&R my front wheel bearing and the brake caliper believe it or not is giving me issues lol. So for sum reason i cannot get anything to remove the caliper guide bolts. On all DIY's it says 14mm socket buttttttt of course i have a hex head bolt(Picture included) does that belong there or somebody before me did something stupid? Also is it possible i can just remove the whole assembly by the bracket instead?
Old Feb 9, 2020 | 08:09 PM
speedlimit's Avatar
Administrator Emeritus
Hi!
Welcome to MBworld!
The W211 forum members might be able to help. Good luck!
Bob
Old Feb 10, 2020 | 12:43 AM
rodneypierce's Avatar
2009 e550 4Matic
The bolt directly below that hex head caliper mounting bolt, would be the caliper bracket mounting bolt. Which would be the 14mm it tells you to remove online. Just remove the two 14mm bolts holding the entire caliper bracket to the spindle and go on your way.
And yes, the hex bolt is what is supposed to be there for the caliper mounting bolt. Thats normal.
Old Feb 11, 2020 | 06:39 PM
08 e350 4matic
the bolts for the bracket where 22mm and the axel bolt was 27mm
Old Feb 11, 2020 | 06:41 PM
2009 e550 4Matic
That sounds correct. I should have known better than thinking they were 14mm. That's my mistake. Glad you got it figured out!!
Old Feb 11, 2020 | 10:24 PM
08 e350 4matic
i thought i was supposed to have a clamp with the 5mm allen head but theres a bolt instead. The diy's on youtube got me all confused lol
Old Feb 12, 2020 | 12:09 PM
08 e350 4matic
Isnt the bearing supposed to slide out?!?
Old Feb 13, 2020 | 01:04 AM
2009 e550 4Matic
No, the 4matic cars the bearings is pressed into the spindle, and then the hub flange is pressed into the bearing. You will have to pull the entire spindle and take it into a shop to have them press the old bearing out, and the new bearing into the spindle, then the hub into the bearing. (assuming you dont know anyone with a press)
Old Feb 13, 2020 | 01:16 AM
08 e350 4matic
how does one remove the spindle?
Old Feb 13, 2020 | 01:27 AM
2009 e550 4Matic
Detach the lower and upper ball joints from the spindle, as well as the tie rod and the stabilizer bar link. Then you should be able to remove the entire spindle/bearing/hub assembly.
