w211 misfire
Received 4,441 Likes
'71 Pinto
Cylinders 4, 5, 6 misfiring & p0021 incorrect position left camshaft. Clear codes if they persist simple first step, check both left side cam magnets. If replacement is decided I suggest replacing all to both sides, 4 in total part # 2720510177.
e350
Misfire
Ok so I cleared codes this more than ran it again and got the following codes, maybe different cause I drove it home from work yesterday uphills and stuff
yesterday
p0021
p0300
p0304
p0305
p0306
today
p0018
p0300
p0304
p0305
p0306
yesterday
p0021
p0300
p0304
p0305
p0306
today
p0018
p0300
p0304
p0305
p0306
'71 Pinto
New P0018 = intake adjustment left cylinder camshaft, same remedy as previously suggested.
e350
Misfire
I am totally confused I thought the sensors are on the driver side or am I gonna do the passenger side. I saw online people saying it was the driver side not passenger. And also is it ok to get buy after market one and do I need to change all 4 or just 2 per side.
is there 1 or 2 on each end of the heads and 2 on the front and 2 on the back
I cant draw an arrow but someone here might be able to point them out. They are at the front end of the cams.
you can get a kit with all 4 solenoids from rock auto for cheap or buy mercedes ones from fcp euro
https://www.rockauto.com/en/moreinfo...fiyagONQ%3D%3D
'71 Pinto
Have you read attachments previously posted. Fault codes pertain to cylinders 4,5,6 on left side of engine. You can start by replacing 2 left magnets (solenoids). I suggested proactively replacing all 4 if a problem is visually found with either left magnet.
e350
So I went to Mercedes and bought the OEM magnets and think that should do the trick the guy at the counter said very common and change one side first then the other if needed. So not the CAM sensor the CAM solenoid magnet
e350
Misfire
Ok so I replaced the drivers side both of them but I still have the same codes popping up after clearing them any more suggestions I just don’t wanna keep throwing parts at this thing
'71 Pinto
e350
Misfire
I sent you a pm and my local indie shop charges like $165 to hook up scan tool what a joke
do you think I should change the oil and both camshaft sensors on the drivers side
If it were me - I would swap the cam sensors from one side to the other and see if the codes change sides.
the cam sensors are one part# ($25/each) and fit both sides.
do that first so you can know if it’s the sensor before waiting to have another part ship. The usual culprit is most likely the simplest - misfires on one side tell you it’s probably timing related so KISS principle tells us it’s likely the cam position sensor. Buy new o-rings for the good sensor your removed as part of the order if that’s the issue to avoid leaks
Changing the oil is irrelevant. Fix the issue first then change the oil after unless you’ve neglected the car and are overdue, but that won’t have any impact on the misfire
e350
Misfire
Well coming home late last night and hopefully this helps someone
2096 e350 w211 gas
I swapped right to left the cam sensors not magnets and swapped the 2 center plugs and coils and pulled the harness on the ecu on top and blew it with air. After doing this it was a little rough start but it started and i throttled it up A few times and bam it ran like a top.
2096 e350 w211 gas
'71 Pinto
