Need help from the airmatic experts
Sorry guys, I was told this is where the airmatic experts were in the forum. This was originally posted in the w219 forum...
Ok, guys, here it is. I just replaced my driver side air strut. It blew out on me. It wasn't a hard job but I ran into a couple of things the YouTube video's don't tell you. Maybe because I have the last year on the W219. They never mention 2011, it's always 06-08 and 09-10 then skips to 12-15 for the w218. But anyway, long story short, I installed the air shock, it inflates and it holds when I turn the car off. But for some reason, after sitting for 24 hours, it drops on the same side I put the new air shock on. I spayed soap water on the connector on top where the air plugs in, no leaks there. I didn't spray the boot yet on the air strut, but it's brand new, and it holds for hours after turning the car off. It's got to be bleeding down from a solenoid valve or somewhere in between. What do you guys think?
Is there a legitimate air leak test on the system I can get? I work with Pneumatics at work, and I was thinking of what's all involved. I don't want to get in the habit of buying parts until the problem is fixed. But this valve seems to be where the problem is coming from, judging by how the car holds the air until after the car sit's for half a day. The valve is the only place (that I can think of) that would loose air over time from sitting. Possible bad o-ring or debris in the valve body... Any other spot like the strut or air line or connector, the leak would be more obvious and keep the compressor running. What do you think?
I'm just speaking from 30 years of working on MB. The only thing you can do is spray the valve with soapy water and see if there is a leak. More times than not I've seen valve issues when we couldn't find an obvious air line leak. The only aftermarket brand air strut we'll use at my shop is Arnott as I've seen countless issues with the china made, ebay type struts. If you bought one of those, I'd be looking at the strut again.
kbanks45 (08-06-2020)
Received 4,441 Likes
'71 Pinto
Have someone with MB diagnostics pull fault codes. No codes, pressurize system (each front strut & rear air spring) in an attempt to identify faulty internals. See attachment for a better understanding.
