E-Class (W211) 2003-2009
Parameter steering pump on non-parameter steering engine
Old Apr 16, 2021 | 09:47 PM
tgarza's Avatar
2006 E350; 2016 XC90, 2019 Suburban; 2005 LR3
I am in the middle of an engine swap, taking out an 06 engine and putting in an 07. the 07 is Not wired for parameter/variable steering and did not come with its own pump.
what are the consequences if I run the pump from the 06 but not hooked up electrically. Will it work ok and will the computers be happy?
Old Apr 17, 2021 | 08:38 AM
kjb55's Avatar
2025 AMG E 53; 2018 GLC300 4Matic; 2003 360 Modena
You could code it as ‘not present’ saving you the error of not being connected.
Old Apr 17, 2021 | 11:16 PM
tgarza's Avatar
how do I code it? New to the brand.
Old Apr 18, 2021 | 07:14 PM
kjb55's Avatar
Dealer or someone with a DAS / Xentry system.
Old Apr 19, 2021 | 10:47 AM
tjts1's Avatar
C320
The perimeter steering control is built into the rack not the pump. I don't know why there's a wire going to your power steering pump take a picture of it.
Old Apr 19, 2021 | 02:17 PM
konigstiger's Avatar
'71 Pinto
Solenoid valve (y10) is wired to ESP module, you may have a problem.
Old Apr 21, 2021 | 09:56 AM
tgarza's Avatar
First photo is the wire going to the p/s pump. It branches off the wire going to the a/c on the 2006 harness. It’s black/pink and red/green.
the plug on the p/s pump sits behind where the high pressure banjo bolt goes in
Old Apr 21, 2021 | 10:54 AM
'71 Pinto
I was approaching from steering gear, misunderstanding you’re referring to 12. You can attempt to manipulate a retrofit (FYI solenoid valve wiring harness 18/33 wiring diagram above is part 2115400709), ultimately wired to n47-5. Not certain if MB diagnostics will eliminate coding for speed-sensitive steering since it is associated with ESP, etc.
Old Apr 21, 2021 | 02:26 PM
tgarza's Avatar
I have a feeling I will need to wire it in to avoid issues. Do I swap wiring harnesses or do a retrofit? Looking for least time consuming option here which is leaning me toward retrofit, but I need to know where to splice these wires in.
