Replacement Loaded Front Struts for 4Matic
On a related note, does replacement of the strut assembly get anymore complicated on the 4Matic? I've watched videos for the RWD cars and it's prettystraight-forward.
Appreciate any insight.
https://www.fcpeuro.com/products/mer...der-2113200026
https://cart.bilsteinus.com/results?...46492326849274
https://www.rockauto.com/en/moreinfo...=7556&jsn=4314
https://www.rockauto.com/en/moreinfo...=7556&jsn=4316
https://www.buymercedespartsnow.com/...ing-2113211504
https://www.fcpeuro.com/products/mer...mer-2113211504
I try to be more conservative in what I'll do for a friend's car vs. my own. I don't want to get into a big time-suck. I'll have to give this one some more thought before agreeing to it.
Taking the struts apart is pretty straightforward. The project is basically getting the strut built with the spring on it. That spring is pretty strong, when I had my mechanic do it, he mentioned it was one of the toughest he had worked on, had to compress it a lot so I'd be real careful with it. That's probably why it's best to just get all the parts and take it to a shop to have it compressed for you. Although mine was a sport suspension and I think yours is the standard one, the sport suspension was lower by an inch so maybe stiffer springs. It does ride nice afterwards so it's worth getting all new parts. Any used strut probably already has 50-100k or more on it and probably not good for much longer. Surprised he got 200k on original struts, they were probably gone a long time ago. The strut makers usually say to replace them after 50-60k. I used to do that on other cars, get Monroe quick struts and then with their lifetime warranty just pay for labor to swap them out again after 60-80k. I've replaced a bunch of other items in there too, ball joints, tie rods, sway bar links, CV joints, upper control arm, etc. I think the sway bars will probably go next along with the bushings.
I was reading this thread because it very much applies to my situation. I have a 2008 E350 4 Matic that has a front suspension problem. From reading and looking at similar pictures it looks like I will need both front shocks / struts replaced. I called the dealership, and even though I gave them the Vin number of the car they were not able to tell me what kind of coil springs I need. They told me that there are no loaded/quick struts available ( which I read in the discussions here also, since my car is 4 matic and not rwd ) and that the dealership will sell me individual parts. My mechanic will do the installation , knows it’s not “Airmatic” but might expect loaded/quick struts ….and they’re not. I am trying to get the parts for him and make it easier , but need help. I looked up info on rockauto.com and fcpeuro.com. I almost don’t know what to get from which website and I still don’t know the color code on my car’s coil springs. If he needs to put the shock,strut, spring together I would like to get all the necessary parts that he will need (like a kit) so he doesn’t run into missing parts problems.
According to the VIN , the car has Sport package 952, and thus is equipped with sport suspension.
Fcpeuro.com lists for instance springs as OE Sachs for $57 , genuine Mercedes at $127 and Meyle at $39. In the Meyle description it says that the original springs have 1 green stripe and 2 yellow stripes (sport suspension), unsure if true until we take the car apart.And never heard of Meyle, are they any good? I am more inclined to go with Sachs. And shock absorbers made by Bilstein, Sachs? This is where I would like to know if I need extra parts, washers, shims,etc. and where to get the “kit”, if I need one.
I hope you guys can help me , I noticed Konigstiger can (somehow) get a lot of information by knowing the VIN Number: WDBUF87X98B310292.
THANKS A LOT!
THANKS A LOT!
https://partsouq.com/en/catalog/genu...UF87X98B310292
