E-Class (W211) 2003-2009
2007 E350 adding siriusxm
Old Jun 26, 2022 | 03:07 PM
Larryjbro's Avatar
2007 E350
Wife inherited this car, new condition, extremely low miles. She wants wants factory Siriusxm, no matter how much it costs me, lol. I bought the module and antenna. I cannot figure out where it goes. All I can find is 2006 and older info. Any help would be greatly appreciated. Nobody has worked at our local MB dealer that can remember back that far, kinda sad after going there first. Thanks in advance. P.S. I did remove the RH trunk trim, nothing there. No wiring at all.
Old Jun 26, 2022 | 03:47 PM
E55Greasemonkey's Avatar
This place is a joke.
It usually goes over the nav drive behind the LH trunk panel. Do you have a nav unit there, or is it integrated in the head unit? Otherwise it may go in the forward part of the trunk under the plastic tray. Give me a couple days I'll see if I can find the retrofit instructions. Meanwhile look for orange fiber optic cables in those areas that aren't plugged in to anything.
Old Jun 26, 2022 | 03:55 PM
Larryjbro's Avatar
2007 E350
Thanks much, I could sure use the instructions, I am a tech at a GM store. I have some ability, lol
Old Jun 26, 2022 | 04:21 PM
That will be helpful, I'm an MB tech. Just fyi once it gets plugged in, the radio will have to be programmed to add sat radio to the fiber optic loop. Only a dealer or someone with Xentry/DAS can do that part.
Old Jun 26, 2022 | 04:24 PM
Larryjbro's Avatar
2007 E350
The guys at the MB store here acted like they had no clue. I want to install it correctly. We do have a local indy shop staffed by ex MB dealer guys.
Old Jun 26, 2022 | 04:57 PM
ot1's Avatar
ot1
2006 E320 CDI
Arrow
The antenna goes on the outside of trunk lid in the center.
Old Jun 26, 2022 | 04:59 PM
ot1's Avatar
ot1
2006 E320 CDI
Arrow
nav drive wasn’t integrated until 2009
Old Jun 26, 2022 | 07:26 PM
Larryjbro's Avatar
2007 E350
question, was that where oem mounted it, I have yet to see one mounted there.
Old Jun 26, 2022 | 08:11 PM
cetialpha5's Avatar
You know you can get a knock off copy of the WIS which is the dealer repair manual on eBay for under $8 right? You should be able to find a 2007 for sale that has it and compare it with your vin that doesn't have it and see what the difference is.
https://www.ebay.com/itm/124959990750
And when you do get it enabled, you can always get those $5/month promos which they do all the time, but you don't get it til you threaten to cancel. Should be able to do a free 30 day trial at least.
https://slickdeals.net/f/14628403-fo...-to-all-access
Old Jun 27, 2022 | 02:29 AM
ot1's Avatar
ot1
2006 E320 CDI
Arrow
The SiriusXM antenna is painted the same color as your car, its a low profile antenna, maybe 3/8” tall. Centered top to bottom and left to right. Factory location. When Properly positioned there will be an opening in the underlid reinforcing. If you need a picture say so.
Old Jun 27, 2022 | 11:23 AM
konigstiger's Avatar
'71 Pinto
SIRIUS was an at cost option for MY07 If vehicle is pre-wired for satellite code 536 will show on data card. If not, best bet would be to go for aftermarket choices. If you want provide VIN I will check for code.
Old Jun 27, 2022 | 12:22 PM
Larryjbro's Avatar
2007 E350
I had the rh trunk trim out, no wiring. We have alldata here at work. Appears the wiring can be added as part of a kit, can of worms, it does have the Sat button on the dash
WDBUF56XX7B182188 is the vin
Old Jun 27, 2022 | 12:38 PM
Did you look in the LH trunk yet?
Old Jun 27, 2022 | 12:46 PM
'71 Pinto
Not pre-wired and not aware of MB kit for 211 facelift models unless offered aftermarket including MOST, power, antenna, etc. tie ins.
File Type: pdf
Old Jun 27, 2022 | 12:55 PM
Larryjbro's Avatar
2007 E350
thanks very much, in alldata, it shows the same kit as the 2006 model for the 2007
Old Jun 27, 2022 | 01:54 PM
'71 Pinto
Attached MB 06 install instructions if it is kit B67830069 this applies to pre-wired vehicles. MB did not release instructions for facelift models 07 >.
File Type: pdf
Old Jun 27, 2022 | 02:27 PM
Larryjbro's Avatar
2007 E350
thanks very much, alldata refers to AZ82.60-P-0006T for 2007 and it does show two lead part numbers. This is crazy complex. Seems like 07 would get simpler as sirius became more common, guess not
Old Jun 27, 2022 | 03:20 PM
'71 Pinto
See attachment.
File Type: pdf
Old Jun 27, 2022 | 03:42 PM
Larryjbro's Avatar
2007 E350
See attachment.
thanks very much, wonder how MB dealers did this when the cars were new, must have been pricey to add the two harnesses.
Old Jun 27, 2022 | 03:52 PM
'71 Pinto
Another ripple that has not been discussed even if you find someone willing to retrofit harnesses your COMAND head unit, although it has SAT button, will not receive all channels due to old software and MB did/does not offer update SIRIUSXM will need to code your subscription into a dedicated tier.
Old Jun 27, 2022 | 04:10 PM
Larryjbro's Avatar
2007 E350
I am at a GM store and we run into that also.
Old Jun 29, 2022 | 08:53 PM
ot1's Avatar
ot1
2006 E320 CDI
Konigstiger would you know if the MY09 SiriusXM radio with the new HU have more channels?
Old Jun 30, 2022 | 11:42 AM
'71 Pinto
See attached bulletin.
File Type: pdf
