E-Class (W211) 2003-2009
ABS, ESP inoperative See Owner's Manual
Old Jan 19, 2023 | 09:11 AM
mbw211auto's Avatar
Mercedes Benz E220 W211
Hi, I drive a 2006 year Mercedes Benz W211 and a couple of days ago after an oil change, I got an abs esp fault, also run flat indicator was inoperative, when I turned on my car fault appeared immediately, the steering wheel became stiff, and when I started to drive it disappeared and the steering wheel came back to normal but my car started to accelerate itself for a few minutes, then abs light and steering wheel stiffness came back, but it drove as usual. No problem with brakes while abs esp fault is on. What could it be? Maybe someone had this issue before. I thought about the abs sensor, but because it has a problem with acceleration I don't know.
Old Jan 19, 2023 | 10:02 AM
JCM_MB's Avatar
2008 E350, 2012 ML350, 2014 E350, 2015 ML350
Before starting to throw parts into it, please scan for codes, and report back.
In the meantime, how old are your batteries: main and auxiliary? Are they fully charged? I think 2006 is a pre-facelift, and it has an AUX battery below the AC filter.
Old Jan 19, 2023 | 10:13 AM
mbw211auto's Avatar
Batteries are new and charged full.
Old Jan 19, 2023 | 10:35 AM
konigstiger's Avatar
'71 Pinto
Have you deleted codes to see if they return.
File Type: pdf
Old Jan 19, 2023 | 10:39 AM
mbw211auto's Avatar
Yes a few times.
Old Jan 19, 2023 | 10:41 AM
JCM_MB's Avatar
Clearly communication errors, i.e. CAN problem. Find the document attached for "pleasure reading"
Perhaps look at the CGW under the driver's side, and clean all contacts first. https://mbworld.org/forums/e-class-w...ml#post7488058
Layman explanation of the CAN bus in MB
File Type: pdf
Old Jan 19, 2023 | 10:50 AM
JCM_MB's Avatar
Just a wild guess. Since the failure appeared after the hood was open, and things moved around, I will definitely check the area shown in this picture before the interior of the car.
Old Jan 19, 2023 | 10:56 AM
mbw211auto's Avatar
Thanks, I will check that. Also, can I still drive it without damaging it more?
Old Jan 19, 2023 | 11:24 AM
'71 Pinto
