E-Class (W211) 2003-2009
I would like your outstanding opinions please
Old Apr 15, 2023 | 12:45 AM
W211-(E500)'s Avatar
2005 Mercedes E500
I have owned my W211 for 4 weeks. My question is enclosed within the attached image. I appreciate your help!
Old Apr 15, 2023 | 08:39 AM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
front end maintenance
it sounds like an airmatic leak issue.... (I am not an airmatic guy)
How many Miles/Km ?
While dealing with suspensions, refresh the wear items at once instead of trying to figure the most worned out rubber one at the time.
FCP Euro parts kit are your friend
Old Apr 15, 2023 | 11:21 AM
konigstiger's Avatar
'71 Pinto
Which side is ‘pump sound’ heard: driver = Airmatic compressor, passenger = SBC unit.
Old Apr 15, 2023 | 11:40 AM
2005 Mercedes E500
Thanks guys - sorry I didn’t post mileage. The vehicle has 115k miles.
The rapid cycling pump sound is coming from the front passenger side. It will only make this odd shuddering noise when in drive and wheels are turned hard right/left. When in park there no noise at all and zero issues with the steering hard right or left.
Thanks you again for your suggestions,
Kevin
Old Apr 15, 2023 | 03:54 PM
'71 Pinto
Not sure how it corresponds but process of elimination. Start simple, need to identify/confirm if SBC hydraulic unit is causing your concern. If so, replacement is covered by extended warranty have MB dealer check it.
File Type: pdf
File Type: pdf
Old Apr 15, 2023 | 04:59 PM
2005 Mercedes E500
Outstanding suggestion. It sure appears that is the area is where I am hearing the sound. It is again a very staccato type pulsing sound. Thankfully it is very consistent with turning the wheel in either direction.
is there anyway to temporarily disengage the SBC unit to help rule out that component?
My steering seems to be functioning completely normal - the steering turning far left or right only seems to instigate the SBC unit. Only on drive will it do this. Never in park.
Im thankful for your insights. I have a Mercedes dealer in town. They could sure look into this and possibly replace that faulty unit if indeed it is causing the issues.
Thank you again - outstanding information
Kevin
Old Apr 15, 2023 | 05:04 PM
'71 Pinto
is there anyway to temporarily disengage the SBC unit to help rule out that component?Kevin
No.
Old Apr 15, 2023 | 11:05 PM
cetialpha5's Avatar
SBC is basically the brake by wire system. If you disable it, you won't have any brakes! Or very minimal.
Old Apr 16, 2023 | 12:05 AM
2005 Mercedes E500
My goodness … we won’t touching that
Old Apr 19, 2023 | 12:42 AM
2005 Mercedes E500
Hello,
it appears I may have found the fix for this issue. It is the front transfer case that is making the shuddering sound at low speeds when turning. Once the front transfer case fluid is changed the issue will be gone.
This also makes sense because when in park there are zero sounds or issues when turning the wheel.
I will do this fluid change very soon.
Old Apr 19, 2023 | 12:53 AM
'71 Pinto
Sounds like the front air pump rapid cycling.
Anyway, see attached bulletin for correct procedure.
File Type: pdf
Old Apr 19, 2023 | 04:43 AM
2005 Mercedes E500
Thank you for that - I will save the information.
