E-Class (W211) 2003-2009
Bearing part number for A/C pully E350 W211 2006
Old Nov 7, 2023 | 11:24 AM
AlleyCat2023's Avatar
E350 W211
Hi,
I am going to replace the bearing for the A/C pully that is causing shrieking noises. I need the part number for the bearing. How can I find it? Can anyone post the part number for the breaking?
Thank you,
AlleyCat2023
Old Nov 7, 2023 | 11:40 AM
nd-photo.nl's Avatar
2005 CLS55 AMG W219 C219
You should be able to find it here: https://mbparts.mbusa.com/
or have a look on FCP Euro etc
Old Nov 7, 2023 | 11:47 AM
E350 W211
Originally Posted by AlleyCat2023
Hi,
Thank you,
AlleyCat2023
I found on Identifix document S-B-83.55/87f that describes the replacement of the pully. However, I can't find the pully part number. It looks like there is a replacement for the pully, and I don't need to press out the bearing. How can I fidn the part number, which is the pully replacement?
Thanks,
File Type: pdf
Old Nov 7, 2023 | 01:39 PM
I would recommend replacing the pulley itself, they are made of plastic. Then you will also replace the dampeners. Coincidentally, I replaced mine not too long ago
Old Nov 7, 2023 | 02:46 PM
E350 W211
I just broke the head of the 7mm hex bolt. From a simple job, it just became a complicated job.
I circled in red the bolt I need to extract, and in yellow the broken bolt (rust all over). The dealer has no part number for it, and I will need a replacement. Do you have a picture of this bolt outside of the pully assembly?
Any ideas how I can extract the bolt to remove the bolt?
AlleyCat
Old Nov 7, 2023 | 05:49 PM
JCM_MB's Avatar
2008 E350, 2012 ML350, 2014 E350, 2015 ML350
AlleyCat
Old Nov 8, 2023 | 06:57 AM
The 7mm bolt is only a counterhold and has a threaded part for the top cover
Old Nov 15, 2023 | 11:03 AM
E350 W211
I can counter hold with a reversed drill and an extraction tool. My next issue is to find the special tool part number:W112 589 07 40 00
The tool is expensive and will take 3 to 4 weeks to arrive from Germany. I can't find a used tool on eBay or elsewhere. Any sugegstions about fabricating a homemade tool, or finding the tool online?
Thank you very much,
Old Nov 15, 2023 | 01:35 PM
I used this tool, bought it on Aliexpress
