E-Class (W211) 2003-2009
Rain water pouring into car.
Old Apr 7, 2024 | 11:01 AM
GunniWho's Avatar
2003 w211 E240
Hello.
I am wondering if anyone knows if there is a drain hole/hose/plug somewhere under the small battery under the airfilter?
it always fills with water there when raining, and from there it comes into the car.
Could not find any information on it via google.
Thanks in advance.
Old Apr 7, 2024 | 03:54 PM
GunniWho's Avatar
2003 w211 E240
Could this be it, the hose above would be to the washer fluid container placed at the back of the aux battery?
Old Apr 7, 2024 | 05:31 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
waterworks...
these are known to seal shut the roof drains by the time rubber tips turn into glue. Smoly cut one corner or replace new.
Windshield can also come unglued in places given enough sunshine exposure.
Use a garden hose or a large cup of water for testing.
Old Apr 7, 2024 | 05:54 PM
GunniWho's Avatar
2003 w211 E240
So there is definitely a drain hole there "under the battery"?
Is it that one I had on the picture (pic from the internet somewhere)?
Old Apr 7, 2024 | 11:43 PM
testing for water sources
Don't get too frustrated with something as simple as a drain.... this is a Mercedes, it has to start leaking.
There's not a lot of water channeled under the battery support.
Try to test where water is coming from and going where...
+++ the drain picture looks like roof drain outlet to me - It's capped so noise doesn't travel into quiet cabin✌️
Old Apr 8, 2024 | 05:55 AM
GunniWho's Avatar
2003 w211 E240
In this case, this drain was the problem, that one on the picture above.
Old Apr 8, 2024 | 03:01 PM
nd-photo.nl's Avatar
2005 CLS55 AMG W219 C219
Is that the one behind the AUX battery? I will also check that to be sure
Old Apr 8, 2024 | 03:53 PM
GunniWho's Avatar
2003 w211 E240
Yes. If you take the right front wheel off, and half of the plastic cover. Its just sitting there easy to dismount with two 10mm. In my case its hard plastic, not the rubber thingies that closes easily.
Fixed my problem.
Old Apr 9, 2024 | 05:40 AM
I think my CLS also has the hardpipes. When I replaced the alarm siren, I extended the hardpipes so the water can go to the underbody paneling as fast as possible without splashing around so much in the wheel well. I did the same on the passenger side
