Sponsored by: CARiD
Bulletins 207 coupe & 212 sedan
Rating: Thread Rating: 9 votes, 5.00 average.
Old Dec 29, 2017 | 05:44 PM
  #351
Exup99's Avatar
E350T Bluetec
11/20/13
Many many thanks
Old Jan 22, 2018 | 11:03 AM
  #352
konigstiger's Avatar
'71 Pinto
Service Campaign 2017120002 JAN18 – 2009-2013 212,164,251 fuel injectors may not meet current specifications, dealer will replace injectors. Approximately 17 vehicles affected.
Recall Campaign 2017120024 JAN18 – 2012-2017 212, 207, 204 steering column adjustment insufficient electrical grounding in column components, dealer will correct grounding and install protective ring to steering column module. Approximately 5,165 vehicles affected.
Service Campaign 2017090009 JAN18 – 2016 117, 218, 212, 207, 463, 166, 156, 292, 172 engine control module in the event of a faulty fuel tank level sensor CEL might not activate, dealer will update ECM software. Approximately 138,674 vehicles affected.
Old Jan 28, 2018 | 02:57 PM
  #353
f35phixer's Avatar
2015 e350 4matic
I would appreciate a data card for VIN: WDDHF8JB0FB135059
A Cardinal Red Beauty, I love that no one else has this car on raod, you never see red ones!!!
Started with a 1985ish 300D turbo diesel , on our forth.
Thanl You
Old Jan 28, 2018 | 04:08 PM
  #354
'71 Pinto
12/4/14
File Type: pdf
Old Jan 29, 2018 | 06:36 AM
  #355
AditaC's Avatar
2014 E 250cdi 4Matic
I would appreciate a data card for VIN: WDD2120821A894798.
Old Jan 29, 2018 | 06:46 AM
  #356
AditaC's Avatar
Many many thanks
Old Jan 29, 2018 | 11:40 AM
  #357
'71 Pinto
9/11/13
File Type: pdf
Old Jan 29, 2018 | 01:09 PM
  #358
AditaC's Avatar
Thank you very much.
Old Jan 29, 2018 | 02:40 PM
  #359
BPhillyBenz's Avatar
'11 350 4matic - '14 Stingray: Gone, BMW 530i, Porsche 944 Turbo, Porsche 356, Mitsubishi 3000GT
Hi Konigstiger! I have been away for a loooong time, but was thrilled when I logged on to see you are still active on this forum. You have always been such great help.
My 2011 e350's Command control knob next to the center console armrest does not work correctly anymore. One night it just stopped having the ability to function by rotating it left or right.
Can you please let me know if I missed a recall or what your professional opinion may suggest?
Many thanks.
Brian
Old Jan 29, 2018 | 03:20 PM
  #360
'71 Pinto
Known/common problem but unfortunately MB has not addressed the matter, no bulletins. DIY repair: https://mbworld.org/forums/e-class-w...mand-knob.html alternative replace unit (about $190 or so) PM VIN if you want part # to comparison shop.
Old Jan 29, 2018 | 03:40 PM
  #361
Many thanks, your help is very much appreciated!VIN #WDDHF8HB9BA268490
Old Jan 29, 2018 | 04:35 PM
  #362
'71 Pinto
$192.32 https://www.parts.com/
$197.23 https://www.mbdirectparts.com/
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old Jan 30, 2018 | 05:45 AM
  #363
f35phixer's Avatar
2015 e350 4matic
Thanks Kon....
Old Jan 30, 2018 | 09:17 AM
  #364
Perfect...thanks for spending the time to help us out. Much appreciated .
Old Feb 6, 2018 | 03:58 PM
  #365
Michael Esa HO's Avatar
W212 E350 (2012), W220 S350 (2003)
Hi Konigstiger and everyone
I am new to the forum, I have just recently purchase my 2012 W212 E350 Avantgarde with CPO (45,000Km). I have recently notice that at low speed the steering wheel makes what I can best describe (from another similar thread) a whipping sound (not creaking or groaning noise), somewhat faint to hear it, I have to turn off the radio to be able to hear it. A member here mentioned in that thread that "its normal", can you please share some light as to why it is or it isnt normal?
Does anyone one else has ever come across this or experience this? I own a W220 S-Class and it never makes such noise.
Thanks in advance.
Michael
Old Feb 23, 2018 | 10:11 AM
  #366
raja777m's Avatar
2014 E350 4M Diamond Silver
Thanks in advance.
Michael
Are you referring to similar issue by any chance?
https://mbworld.org/forums/e-class-w...r-estimat.html
Old Feb 23, 2018 | 11:35 AM
  #367
Rovel's Avatar
2007 E63 Amg
Thanks in advance.
Michael
Your issue might be different, but I experienced something similar with my 2013 E550 which is the the W212 body style. Below is the excerpt from the dealer invoice (thanks God was covered by the ELW)
Cause: STEERING SHAFT BOOT AND BEARINGS
Correction: ROAD TESTED VEHICLE, CONFIRMED SQUEAKING NOISE FORM STEERING SHAFT AT FIREWALL AREA. REMOVED UPPER STEERING SHAFT FROM STEERING COLUMN. R&R REAR LOWER ENGINE PANEL. REMOVED UPPER STEERING SHAFT FROM LOWER STEERING SHAFT.
REPLACED UPPERSTEERING SHAFT BOOT THROUGH FIREWALL AND BOTH
BEARINGS.REASSEMBLED, NOISE GONE.
Old Feb 23, 2018 | 12:40 PM
  #368
'71 Pinto
Service Campaign 2018020005 FEB18 – 2015 & 2016 207, 212 engine control unit does not correspond to current production configuration, dealer will perform SCN coding. Approximately 10,897 vehicles affected.
Old Feb 28, 2018 | 05:17 PM
  #369
Hi Rovel,
Exactly what the dealer diagnosed and did as well. Thank goodness that I also have extended warranty.
Does anyone know if there was ever a bulletin regarding this matter?
Michael.
Old Mar 16, 2018 | 02:43 PM
  #370
terefpat's Avatar
W212 E550
What do these characters correspond to? Is this info I should provide to my service writer if this is an issue with my vehicle? Will it be covered by the manufacturer/dealer?
Old Mar 16, 2018 | 09:38 PM
  #371
terefpat's Avatar
W212 E550
WHAT NOW?
LI32.22-P-052062 – 212 thumping from area of the front axle when driving over speed humps when the suspension strut rebounds, the rebound buffer spring causes a metallic knocking noise. Dealer should flash Airmatic control unit.
LI54.21-P-052072 – vehicles with 276/278 engines CEL in IC but engine does not display any problems (i.e.: fault code P060600) update ECU.
So what do I do if I’m affected by one of these TSB’s? Do I just show my service advisor the TSB number?
Old Mar 17, 2018 | 11:35 AM
  #372
'71 Pinto
Normally bulletins are only covered under factor and/or extended warranty at no cost. In your case software updates correct known production flaws contact MBUSA direct to request no cost goodwill repairs 800-367-6372 referencing bulletins numbers afterward print attachments to show SA.
File Type: pdf
File Type: pdf
Old Mar 27, 2018 | 07:38 PM
  #373
Sunnyslope48's Avatar
2016 E350 Sport 2WD
How can I find out if this pertains to my vin # ( WDDHF5KB9GB203261) ?? I do my own required maintenance. Perhaps there is a web page where I can inquire?
Old Mar 28, 2018 | 12:14 PM
  #374
'71 Pinto
Dealer needs to check VMI.
File Type: pdf
Old Mar 28, 2018 | 04:51 PM
  #375
'71 Pinto
LI46.10-P-067941 MAR18 – 212, 204, 207 steering wheel area grinding and/or clicking noises, contact bridge may grind on the steering column switch module.
You have already rated this thread Rating: Thread Rating: 9 votes, 5.00 average.
