Bulletins 207 coupe & 212 sedan
Another question I have is about the speaker melting issue with the subwoofer. Is there any bulletin?
No bulletins. Unless everyone in every market requests their dealer to report this defect/malfunction, even if out of pocket repair, nothing will be done concerning MB acknowledgement/goodwill repair.
Recall Campaign 2019110005 NOV19 – 2013-2017 CLA-Class (117), GLA-Class (156), M-Class/GLE/GL/GLS-Class (166), SLK/SLC-Class (172), AMG GT-Class (190), GLK/C-Class (204), C-Class (205), E-Class Coupe/Cabrio (207), E-Class (212), S-Class Coupe/Cabrio (217), CLS-Class (218), S-Class (222), SL (231), B-Class (242), GLC-Class (253), GLE Coupe-Class (292), G-Class (463) communication module might not meet current production specifications used to communicate the vehicle’s location for the emergency call system, in addition to other convenience features. Note that some vehicles may have already successfully received an “Over-the-Air” (“OTA”) update. Customer letters will be mailed, approximately 24,473 vehicles affected.
Thank You, issue was addressed to dealership and they fixed it while the vehicle was in shop for other issues.
LI03.10-P-052286 SEPT11 knocking noise from engine, inspect cylinder walls for scoring if found engine must be replaced. Affected vehicles are mostly production dates from 8/10 to 11/10 but might be outside this range situation was corrected as of engine # 2729xx 31932895 & 2739xx 30441186.
LI27.60-P-049981 OCT11 hard shifts, poor start characteristics, uncomfortable jolting – check oil level, check for software releases and check engine for unmetered air.
Came across this thread after researching knocking noise from Engine..
My VIN is WDDHF5GB5AA025158 and it appears my engine number is 272980 31 237769 from MBEPC???
Engine no.:272980 31 237769
Major assembly variant: A 272 010 51 46
Part var. design.: 27298030
Text
BITTE BASISMOTOR A 272 010 84 98 80 BESTELLEN.
PLEASE ORDER BASE ENGINE A 272 010 84 98 80.
If that is correct, it appears my engine number would fall in the range of when this issue was corrected?
Are these bulletin/recalls etc.. honored even if outside of warranty?
BTW, great thread!!
Also a data card for VIN: WDDHF9BB4EA968274 would be helpful.
Thanks so much,
Also, what values can the EPS learn exactly? Never heard this mentioned before.
Basically erasing/resetting, see attachment.
Could you please pull the Data Card for VIN: WDDHF7GB1FB101701 ?
Thanks again for your tireless service here
Scott
Thank you very much!
Scott
