Bulletins 207 coupe & 212 sedan
#451
Looking for information on this SW update
There is a firmware update MB is pushing: 2019040001 ENG. SFT. - SA said that MB was doing this to bring all affected cars within "specification". After reading some other's experience with issues after this update was applied, including loss of power, we asked them not to apply this. Just got the car back and paperwork said they did not. Need to take a drive w/o wife to see how it feels, but felt normal at low throttle on the drive home...
#452
This was posted about the time my car went in - doesn't have that campaign number and yes it was diesels. Frankly whatever might be "out of specification" is just fine by me on my car. I found it interesting that the M278 in the lighter '14 E550 tested in reviews slower than the '12s. I'll stick to my paranoia...
https://mbworld.org/forums/e-class-w...-mercedes.html
#453
WDDHF5KB4EA914479
My dad got this car, I am trying to figure out if the spark plugs have been changed? Anyone have access to VMI?
Thanks!
Thanks!
#454
WDDHF5KB4EA914479
Thanks!
Thanks!
#455
2016 E63 S AMG Wagon
This may be a toughie. Just purchases a Canadian 2016 E63 S AMG Wagon. It came with no useable service data (Car came with all manuals and service booklet, but for a different VIN!) Only a shrug from selling dealer...not MB. MBUSA does not provide recall info on non-USA vehicles. My VIN is WDDHH7GB4GB202047 if you can provide any information. TIA
#456
Received 4,431 Likes
'71 Pinto
See attachment for service requirements. For MB service history you will need to contact dealer to request Vehicle Master Inquiry (VMI) they should readily provide info verbally however, dealer discretion dictates for providing hardcopy.
Yakatak (01-30-2020)
#457
I had a couple of different questions. First question is I have 2014 E350 Sport and the driver seat cushion is coming apart at the seams, wondering if there was a thread on this and if others have this issue. Second question is, does anyone have link or a website that sells matte black grilles for my model of car along with other matte black accessories? Thanks in advance everyone.
#458
'71 Pinto
#459
My car is currently having a "support clip" installed on the IC for a rattle from the gauge cluster. I cannot find any such TSB in this thread - the closest I found was
LI68.10-P-061068 MAR15 – 218 instrument cluster noise, dealer will apply felt to IC facade.
But that's for the CLS. Any idea what they might be doing to my car?
#460
'71 Pinto
To my knowledge not aware of any bulletins, question would best be directed to dealer. Anyway, here are the connecting points.
#462
'71 Pinto
#463
Seems typical SA BS. He said something about support clip TSB.. today he said the tech removed and reinstalled the IC and the rattle noise is gone. No further mention of a TSB. Picking car up tomorrow, fingers crossed that nasty rattle is gone.
#464
Diesel engines, unlike gasoline engines, do not use spark plugs to induce combustion. Instead, they rely solely on compression to raise the temperature of the air to a point where the diesel combusts spontaneously when introduced to the hot, high pressure air.
#465
Post above was about dashboard rattle by Instrument cluster
#467
2015 ML400 4MATIC, 2014 E350 4MATIC, 2006 E350
WDDHF8JB0EB050656
Hi, i was wondering if i have any service bulletins or recalls associated with my vin. Thanks
I know my vehicle is associated with the Bolts for the steering gear, but not sure if there is anything else. Thanks
#468
Are there any bulletins for E250 BT WDDHF0EB9FB123990 for somewhat rough 1-2 shifts when cold? I also get a very occasional slamming downshift when driving aggressively, usually when rapidly transitioning from braking to acceleration.
Car is 2015 with 35k, hasn’t had transmission fluid changed yet. I also have not reset the adaptive shift logic yet. If that is recommended the procedure would be very useful. Thanks ahead of time for any help.
ccww (06-20-2020)
#471
'71 Pinto
LI46.35-P-071461 JUL20 - All models w/electric steering knocking noises when driving or steering, check wear of tie rod outer joint.
LI46.35-P-071462 JUL20 – All models w/electric steering knocking noises when driving or steering, check wear of tie rod inner joint.
The following 2 users liked this post by konigstiger:
CaliBenzDriver (03-25-2021),
fc3 (08-25-2020)
#472
'71 Pinto
218
LI27.50-P-071658 AUG20 – Vehicles w/725 transmission when changing gear range from P to D or R harsh engagement may be noticeable, the engagement sequence must be taught in again as follows: Start the engine from cold: engage gear P, wait at least 5 seconds; gear D, wait at least 5s; gear P, wait at least 5s; gear R, wait at least 5s. Repeat this process for the engagement processes into D and R 10 times. Then drive the vehicle in up to 3rd gear max., to cool the plates. Also repeat the above procedure with the transmission at operating temperature (approx. 50°C) and running hot (approx. 70°C).
#473
'71 Pinto
LI35.30-P-058566 SEPT20 – 171,172,203,204,205,207,209,211,212,213,215,216,21 7,218,219,220,221,222,223,230,231,238,253,257, 164,166,167,292,293 single throttle lift-off clunking noise from the side shaft when moving off (audible at the outboard end) noise is heard once in each instance when changing direction of travel. If the complaint is eliminated by experimentally loosening the outboard collar nut (by 1 turn), the problem is due to cracking of the microweld between the wheel bearing inner race and the joint housing of the side shaft. The collar nut must always be replaced after being loosened. Coat contact surface of side shaft with wheel bearing with Molykote paint (MB part # 0009890152).
LI33.30-P-056665 SEPT20 – All Mercedes-Benz cars with front-wheel drive and 4x4 vehicles single throttle lift-off clunking noise from the side shaft when moving off (audible at the outboard end). The clunk is heard once when changing from forward to reverse (and vice versa). If the complaint is eliminated by experimentally loosening the outboard collar nut (by 1 turn), the problem is due to micromovement in the connection between the wheel bearing inner race and the joint housing of the side shaft. The collar nut must always be replaced after being loosened and must be tightened to the specified torque. Coat contact surface of side shaft with wheel bearing with Molykote paint (MB part # 0009890152).
LI27.50-P-049281 SEPT20 – 722.9 transmission when changing gear range from P to D, harsh engagement may be noticeable, engagement sequences for N-D and N-R must be taught in again as follows (always remain in the gear ranges N/R/D for at least 5 sec): start the engine from cold, shift 5 times N-R, shift 5 times N-D -> warm up transmission to 40°C and while doing so, exceed a speed of 30 mph at least once. Shift 5 times N-R, shift 5 times N-D -> warm up transmission to 70°C and while doing so, exceed a speed of 30 mph at least once. Shift 5 times N-R, shift 5 times N-D.
#474
'71 Pinto
Service Campaign 2020110018 DEC20 – 2013-2017 117, 156, 166, 172, 190, 204, 205, 207, 212, 217, 218, 222, 231, 242, 253, 292, 463 PASS control unit does not meet current series production configuration and therefore the possibility exists that a correct GPS position cannot be determined, dealer will update the control unit software. Approximately 31,707 vehicles affected.
Hk91308 (01-26-2021)
#475
'71 Pinto
Emission Campaign 2020050029 MAR21 – 2014 & 2015 212 diesel (651 engine) emission modification dealer will replace certain emission control system components and update certain software at no cost. Approximately 482 vehicles affected. Approximately 2,554 vehicles affected.
Emission Campaign 2020050030 MAR21 – 2016 212 diesel (651) emission modification dealer will replace certain emission control system components and update certain software. Approximately 482 vehicles affected. Approximately 629 vehicles affected.
Emission Campaign 2020050031 MAR21 – 2014 & 2015 212 4matic diesel (651) emission modification dealer will replace certain emission control system components and update certain software. Approximately 482 vehicles affected. Approximately 2,050 vehicles affected.
Emission Campaign 2020050032 MAR21 – 2016 212 4matic diesel (651) emission modification dealer will replace certain emission control system components and update certain software. Approximately 482 vehicles affected.
