Sponsored by: CARiD
Bulletins 207 coupe & 212 sedan
Rating: Thread Rating: 9 votes, 5.00 average.
Old May 3, 2013 | 01:53 PM
  #126
konigstiger's Avatar
'71 Pinto
Service Campaign 2013040003 MAY13 – 2013 models 212 & 218 right horn bracket may not be to specification, dealer will re-torque.
LI88.30-P-056180 MAY13 – 218 front wheels with 18-inch tires scrape against front wheel liner, replace wheel well liners inclusive of front engine compartment paneling.
Old May 7, 2013 | 06:33 PM
  #127
tonyep's Avatar
X156, C117, W212, W222
LI42.10-P-054524 SEPT12 – 212.072/090/272 front brake vibration. Thickness fault on brake disk replace pads and disks.
Does this apply to a 2012 E550 cab? I am experiencing vibration under braking especially in freeway. Car has less than 8000 miles and 1y1mo old and the dealer is refusing warranty.
Old May 9, 2013 | 06:02 PM
  #128
'71 Pinto
Bulletin documents only 212 however, EPC shows original front brake discs replaced for 207.473 (E550 Cabriolet):
Front part # 2214210812 replaced by 2044211212 – request service manager get MB rep covering dealership involved to approve replacement considering mileage and only one month out of 12 month/12,000 MB brake warranty https://mbworld.org/forums/2089508-post1.html
File Type: pdf
Old Jun 5, 2013 | 04:03 PM
  #129
'71 Pinto
LI67.30-P-056196 MAY13 – 207 up VIN F215729 vertical scratches on front and/or rear windows replace window and install new trim strip.
LI49.20-P-056353 MAY13 – 212, 218, 164, 166, x204, 221, 251, 463 with 642 BT engine (code U42) heating element of AdBlue tank malfunctions, replace faulty components program SCR control unit with new software.
LI07.08-P-056434 MAY13 – 276 engine intermittently shuts off at idle when vehicle is stopped for some time at a stop sign, traffic signal or similar traffic situation. Update MED control module software.
LI01.60-P-056340 JUN13 – 276 engine thread on timing case in area of oil filter housing shows signs of leakage (see attachment), install new bolt 0029901103.
LI62.25-P-056043 JUN13 – 212 & 218 deformation of engine compartment soundproofing due to water ingress. Install optimized seal part # 2126280800.
Attached Thumbnails Bulletins 207 coupe & 212 sedan-056043_1.jpg   Bulletins 207 coupe & 212 sedan-056043_2.jpg   Bulletins 207 coupe & 212 sedan-056043_3.jpg
File Type: pdf
Old Jun 7, 2013 | 01:16 AM
  #130
2006_C350's Avatar
2010 C300 & 2014 E350
Both, check PM
Do they do an alignment after replacing two front struts?
Old Jun 7, 2013 | 11:36 AM
  #131
Nuru's Avatar
S350 BT 4MATIC
Yes they should. Matter of fact, if you have a 4MATIC, they should complete a 4 wheel alignment.
Old Jun 12, 2013 | 06:08 PM
  #132
greasykid's Avatar
2015, ML250 BlueTEC
Water leak help
My 2012 W212 Vin A617810 leaks water into the foot well on the drivers side. Is there any TSB on this? Appreciate any info before I take it into the dealer.
Old Jun 13, 2013 | 03:12 PM
  #133
El Cid's Avatar
Veteran: Army
2010 E350 Luxury Sedan, Engine 272 (V6)
What kind of water?
I had a car once where water was leaking from the A/C into passenger floor due to poor assembly quality and design of drain location. Does it leak in rain? when washing car? Turn a hose on windshield and then on the area at base of windshield. Might help narrow it down.
Good luck!
Old Jun 14, 2013 | 11:51 AM
  #134
greasykid's Avatar
2015, ML250 BlueTEC
Water leak
Good luck!
Seems most noticeable when I hose the car down for a wash.
Old Jun 14, 2013 | 05:16 PM
  #135
BenzMan369's Avatar
2012 E350 Coupe
Konigstiger:
With reference to Post #159 dated yesterday in this Forum: https://mbworld.org/forums/e-class-w212/446961-2012-e350-blown-motor-less-than-1000-miles-what-my-options-7.html
Are you aware of the TSB which the poster states his dealer informed him exists, necessitating a 2012 E350C engine rebuild due to bad wrist pins?
Sincere thanks, as always!
Old Jun 16, 2013 | 11:12 AM
  #136
Erling's Avatar
MB
Yes. I had my front rotors replaced on my 550 cab for this very reason. HOWEVER the dealer was very specific that they did me a "favor" as a long-time customer as I had the service done just after one year and they would not do it over 12K miles or 12 months.
I would take it in ASAP if you're at 13 months now
Old Jun 26, 2013 | 11:48 PM
  #137
sentralfyr's Avatar
2015 S205 AMG
Delivering my car for replacement of front and rear windows
Took a while for the local dealer to confirm
Old Jul 6, 2013 | 06:00 PM
  #138
'71 Pinto
Service Campaign 2013050005 JUN13 – MY 2011 212, 204 and X204 transmission noise, may not meet internal specifications replace transmission. Approximately 17 vehicles affected. Have dealer check VMI to see if vehicle is included.
LI82.61-P-056388 JUN13 – Becker MAP PILOT navigation announcements inoperative, update software to navigation module.
LI27.19-P-056458 JUN13 – 212.098 & 298 (BLUEHYDRID), 212.095 & 195 (HYDRID) various transmission complaints, flash transmission control unit - automatically flashes engine control unit (ECU), battery management system (BMS) and power electronics (LE_TUBE) at the same time.
LI09.20-P-056492 JUN13 – 212,077 & 277 (E63) up to engine # 60 005808 CEL lights up / engine shakes at idle, replace intake manifold seals using modified aluminum mounting bolts.
Old Jul 10, 2013 | 12:37 PM
  #139
mattbta's Avatar
2012 E350C
Subbed.
Old Jul 10, 2013 | 04:13 PM
  #140
samkimg's Avatar
2023 XC60 PHEV, 2023 XC40 BEV
konigstiger - two questions ...
1. '71 Pinto, really?! I had one of those until we dropped a V8 in the back and turned it into a dragster. It died an honorable death when a driver wrapped it up a few times too many ...
2. I see some Service Bulletins/TSB's/LI's that mention a specific model year (MY) and some that don't. How do I tell the differences between MY variances?
Old Jul 10, 2013 | 06:00 PM
  #141
'71 Pinto
Originally Posted by samkimg
'71 Pinto, really?!
If bulletin references model year (MY), production range, and /or VIN range etc. coverage is of course limited. If not, bulletin should cover listed model(s) regardless of MY and VMI (vehicle master inquiry) confirms eligibility - i.e.: bulletin references modified part without MY, given production date VMI and/or EPC (electronic parts catalog) should confirm if part was already installed at production.
Old Jul 16, 2013 | 02:34 AM
  #142
noyu's Avatar
17 E43, 18 GLE400
LI88.20-P-052891 - 212 rear bumper sticks out in area of rear lamp. Bumper experiences thermal expansion mounting rails (fender area) cannot sufficiently hold the bumper in place. If bumper is not equipped with additional latch, it should be replaced. Note since JAN11 bumpers are equipped with additional retaining tab.
Hi D,
My new to me MY10 E550 has this bumper issue is that possible you can send me a copy of the bulletin?
Old Jul 18, 2013 | 01:02 AM
  #143
AnirInTexas's Avatar
2011 E-350 P2 Cuprite Brown/Chestnut
Originally Posted by noyu
Hi D,
My 2011 e350 had the same bumper issue. Please send the bulletin.
Old Jul 20, 2013 | 11:34 AM
  #144
jumpman726's Avatar
2024 E350
Konigstiger, thank you for posting this info.
I dropped my car off (2012 E550 sedan) at the dealer a couple of days ago because of a vibration in the steering wheel while braking, along with a strange noise in the front which I thought was normal.
The tech could not find anything wrong. I then went online and found this forum and I think I found two service bulletins you posted that apply to my car.
LI42.10-P-0555595 FEB13 – 212.091 E550 4matic, grunting noise from front axle area during medium / hard braking (similar to allowing vehicle to creep slowly from a stationary position with brakes partially applied), replace front brake pads.
I emailed the dealer with the info and hopefully they end up replacing the brake pads and disks on my car. One question, when Mercedes issues a service bulletin and the dealer performs the repairs they are reimbursed by Mercedes for parts & labor, right?
Old Jul 20, 2013 | 11:45 AM
  #145
'71 Pinto
Yes, if under warranty.
Old Jul 20, 2013 | 03:40 PM
  #146
2006_C350's Avatar
From my understanding, yes they get paid for the parts and labor but they have an internal labor rate that amounts to less than what a private mechanic would get paid. Maybe even 30% less than a private mechanic sometimes. This is why dealers are annoyed at doing warranty work. Can anyone chime in on this?
Old Jul 20, 2013 | 04:20 PM
  #147
'71 Pinto
Correct, discounted labor & parts
Old Jul 21, 2013 | 10:17 PM
  #148
aeroconfigs's Avatar
w212
LI32.25-P-051123 FEB11 – 212 without Airmatic (489), 207 without vehicle dynamics (483) dull thumping noises or metallic rattling from the area of the front axle occurring @ speeds 10-45 mph, modified front struts should be installed.
LI42.10-P-051397 MAR11 – 212.077/277 without AMG ceramic brake system (B07) low mileage rear brake squeal, dealer should check batch # installed if within affected range 250-10; 264-10, 278-10; 288-10; 292-10; 307-10 pads are to be replaced.
Could you please pm me LI32.25-P-051123 FEB11 ? I have been getting the dull thumping while turning sharply at low speeds.
Old Jul 22, 2013 | 10:14 AM
  #149
jumpman726's Avatar
2024 E350
The dealer says the tech knew about the bulletins, but refuses to replace the pads or rotors under warranty because my car is 19,000 miles (warranty for pads & rotors is 12,000 miles) and doesn't feel the vibration is bad enough. They said if I want to replace the front pads and rotors it's close to $1,000. Very disappointed.
Old Jul 30, 2013 | 08:15 PM
  #150
mistert2's Avatar
2013 E350 Coupe
Which dealer is refusing to do the work? Get the word out via this forum, yelp, etc. to warn your fellow MB owners. A premium brand should take care of the owners of their cars. Thanks.
You have already rated this thread Rating: Thread Rating: 9 votes, 5.00 average.
