Sponsored by: CARiD
Do your intermittent wipers go thump?
Old Nov 11, 2009 | 09:12 PM
Philco's Avatar
2010 E550 Sedan; Sold 2000 S500
I had my intermittent wipers on for the first time today and they drove me crazy! Every time they came up from their "parked" position the far end of the passenger side wiper thumped against a piece of plastic/rubber on that side of the windshield. I had to keep the wipers in constant wipe mode so it wouldn't happen. I searched and didn't see anyone else post about this problem on this group yet. Is anyone else having this loud thump from their wipers?
Old Nov 12, 2009 | 10:47 AM
emilner's Avatar
S560
Sounds like they are out of adjustment. My wipers chatter after 10 minutes of use but they don't hit anything...
Old Nov 12, 2009 | 05:11 PM
silberrosa's Avatar
Could be they are hitting the windshield trim. If this is the case, it is because the blades have been installed incorrectly. Try swapping them and see if this fixes the problem. I have seen this happen and it could be the case as they are right/left specific.
Old Nov 12, 2009 | 10:35 PM
Philco's Avatar
Thanks for the feedback. It is definitely hitting the windshield trim. I will try swapping them.
Old Nov 13, 2009 | 12:15 AM
bowbyeal's Avatar
2010 350E 4MATIC
I had the same problem when I took delivery of my E350 4MATIC about a month ago. It turned out the two windshiled wipers are of different lengths and they had been installed on the opposite sides of where they should be.
I took it to the dealer and they reversed them and the problem was solved.
Old Nov 13, 2009 | 06:19 PM
Philco's Avatar
That was the problem! The wipers were swapped. Thanks for the help! Swapping them back was super easy too! Great design. I can only imagine how much they will cost to replace.
Old Nov 15, 2009 | 08:15 AM
mm9351's Avatar
2020 GLE450 polar white AMG pkg.
Exclamation another E350 with wiper blades reversed
My wipers were also making that annoying thump; almost seemed that the mechanism was not sync'd properly.
Following everyone's advice here, I just swapped the left / right blades and everything is perfect! Appears that the driver blade is 2.0 " longer and this interferes with the windshield molding on the passenger side, when installed improperly...
Now, how could MB not be checking this at some point? Factory, dealer prep, final inspection? At least 4 people here (myself included) with this issue.. I'm sure there will be others.
Glad it was a simple fix, however! Many thanks to the OP and all who replied.
Old Nov 15, 2009 | 08:21 AM
aeggroup's Avatar
2025 Range Rover, 2022 BMW M850 , 2017 MB E400 Coupe
I went yesterday to my local dealer to choose the E I'd like and when we got the car and started to drive it on a lot - I noticed the car has small wipers instead of regular ones. The dealer told me this is delivery wipers and normal wipers are in the trunk and they install it at the time of delivery. So..I assume it's normal when they don't know what they doing and switch driver's and pasenger's side wipers ...LOL
Old Nov 15, 2009 | 08:59 AM
mm9351's Avatar
Mystery solved. Good catch, aeg!
In a few random cases, odds are the dealer will eventually get it right the first time.
