Sponsored by: CARiD
Wheel Thread
Old Apr 3, 2017 | 08:58 AM
  #101
jahquan3's Avatar
2010 E550 P2 w/AMG Sport Package + Pano, 2015 Nissan Pathfinder
Originally Posted by Diesel #2
I don't get it. If the insurance is putting up the brunt of the money why are you leaning towards the cheaper wheels. You already paid $1000 in deductible right ? While you have this opportunity, get the best wheels possible. Whether you get BBS, Vossen, Vertini or HRE the cost to you is the same. Is there is a limit as to what the insurance company will spend on the wheels ?
Whatever you do [as your cyber friend lol] please do not get those hideous BBS, especially in 18s. It will make your gorgeous w212 look inadequate. Also, If you want 18s, i would highly recommend that you search more towards silver or titanium finishes.
The way my insurance works is they just deduct the 1k from the total. So it was roughly 4k for all the work and they're cutting me a check for 3k. The BBS CH OR CH-R Black are much better looking then the one I posted earlier. They look very similiar to the BBS's the gentlemen just posted above if not the same.
I just purchased tires not to long ago which are 18s so I'm staying with that since I'm not swapping out my tires as well to fit a new set size. Normally I would agree with getting the nicer rims but this wasn't by choice to swap out my rims. So I'm planning to stay as simple as possible and def. not go over that amount even with the labor included. Sadly all the ones I personally like aren't even 2k combined. So I'll probably have some cash left over if things go as planned. I have an appointment to go to a rim shop in my area and maybe I'll see something in there I like more and spend more. I'll be reporting back as things move along.
Old Apr 3, 2017 | 09:01 AM
  #102
jahquan3's Avatar
Just to add, I figure if anything is left over, I'll use that to possibly repair the damaged rims. Then I'll have two sets and can sell one or keep them as an extra in case any more potholes give me problems. I cannot realistically see having 19s or 20s on the roads I drive on. I've already had 3 tires blowout with 18s as is.
Old Apr 4, 2017 | 12:18 AM
  #103
berti_00's Avatar
2016 Cls63s AMG
whats a good offset for these cars... for 19 inch with Vogtland springs.
is et35 all around 8.5 and 9.5 to small of an offset?
Old Apr 4, 2017 | 12:22 AM
  #104
alamry's Avatar
2014, E350 ,4matic, luxury package, AMG kit
Fronts: 19x8.5 w. 235/40 tires
Rears: 19x9.5 w. 265/35 tires
Hey Diesel #2, i dig it man, your wheel setup is cool
what is the offset on those wheels ? and will the same offset fit flash on my 2014 E350 4matic with Vogtland springs 245/19 front 285/19 rear tires ?
Old Apr 4, 2017 | 04:07 PM
  #105
Diesel #2's Avatar
2016 E 250 Bluetec
Thank you.
The fronts are ET 32 and the rear is ET 42. In my experience a 9" wide wheel sits flush up front and a 9.5" wheel sits flush in the rear. 285/30/19 might rub on speed bumps and sharp dips on the highway if you are lowered. 275/30 might be a better choice. But im not sure about that, 285/30 might work without rubbing as well. Good luck, let me know if you need other info.
Old Apr 5, 2017 | 06:28 AM
  #106
BBB78's Avatar
W212
Depends on the tire size and if you are lowered.
You can fit plenty of wheel on these cars. I'm running 9.5 fronts and 11" rears
Old Apr 5, 2017 | 11:59 AM
  #107
AllenOU's Avatar
2014 E350 sport
So here is mine. 20X8.5 and 20X9.5 CEC882s that I powder coated black. The H&R springs really made the look imo. RIDES GREAT!!!!
http://imgur.com/r1miGU0
http://imgur.com/Dprw1GO
http://imgur.com/SUdZhAe
Old Apr 5, 2017 | 06:38 PM
  #108
berti_00's Avatar
2016 Cls63s AMG
thinking 235 35 front and 275 35 or 30 rear lowered on vogtlands?? and all this with ET35 all around..
what do you think
Old Apr 5, 2017 | 11:55 PM
  #109
alamry's Avatar
Thank you.
Many thanks for the info Diesel #2.
Old Apr 6, 2017 | 12:04 AM
  #110
BBB78's Avatar
W212
what do you think
zero issues with those tires and offsets
Old Apr 6, 2017 | 01:18 AM
  #111
larrywoods3's Avatar
2010 E350 P2
Old Apr 6, 2017 | 11:56 PM
  #112
berti_00's Avatar
2016 Cls63s AMG
anyone think these would look decent?
19x8.5 front et35 245/35
19x9.5 rear et35 275/30
https://www.aspiremotoring.com/produ...atte-gun-metal
Old Apr 7, 2017 | 06:22 AM
  #113
Airmousam's Avatar
2010 E550 4M P2 Distronic, CLK550 Cab P2
Originally Posted by larrywoods3
I like it!!
Old Apr 7, 2017 | 10:26 AM
  #114
jahquan3's Avatar
^^Me too.
Old Apr 7, 2017 | 02:33 PM
  #115
jahquan3's Avatar
I had a vendor tell me that a staggered setup of 18x8.5 18x9.5 would still fit my tires even though my setup is now 18x8.5 18x9. Is this true?
Old Apr 7, 2017 | 05:05 PM
  #116
Diesel #2's Avatar
2016 E 250 Bluetec
Tires usually have about a 1.5 inch range as to the wheel size you can fit. But you want to be at the lower part of the range so your wheels sit inside of the tires more, if you know what i mean.
A 245/40/18 tires can fit wheels from 8-9.5", however if you run a 9.5" wheel [depending on the offset] it will probably look like this. The wheel will won't have any tire to protect it against curbs so you will most likely end up scuffing your wheels up more often. Besides that, it is not too appealing to the eyes either.
Old Apr 12, 2017 | 09:09 AM
  #117
jahquan3's Avatar
Thank you. That's a perfect explanation and gives me a visual of what I'll be working with.
Old Apr 16, 2017 | 02:18 PM
  #118
pgh2atl's Avatar
E350
Can anyone give me recommendations on a 19x8.5 front/19x9.5 rear setup for offset & tires? I just want the wheels to be flush. I've got a '12 base E350 on a normal suspension. No plan to lower....
Old Sep 7, 2020 | 02:25 AM
  #119
Johnny Rad's Avatar
W212 E550 4M P2
Offset question - Can I safely go from my square +48 wheelset to a square +35 wheelset running the stock stock 245x40x18 tires on stock 18x8.5 48 rims? Online wheel calculators show the +35 wheelset will stick out ~0.51" versus my stock set.
Old Nov 27, 2020 | 11:56 PM
  #120
Derek Leffert's Avatar
E350
Any additional pics? Or links to where you got them?
Originally Posted by piper
AMG Replicas - 20X8.5 & 9.5
Old Nov 29, 2020 | 08:20 PM
  #121
Quattrodude's Avatar
2011 E550 - 4Matic, 2008 ML550
I have an E550 4M - had off set of 48 orig. with the stock 18 x 8.5
Ended up with same 18x8.5 but now with a 35mm off set - I do have the airmatic suspension but dont think that changes spacing
- but here are the pictures so you can see how they look - still with 245 40 18's never had any issues with rubbing even with 4 adults in the car on Sport or comfort mode.
Front\Back and full side picture
Side view
Back wheels - The wheel is flush with the back
Top Front - sorry wheel is turned slightly but you can see
