Sponsored by: CARiD
Does the center console/armrest inside storage light protrude through the crack?
Old Jul 18, 2011 | 04:03 AM
K-A's Avatar
K-A
Porsche Macan S SportDesign / Ex M-B's: 11 & 10 & 06 E350's, 02 S500
Does your center console/armrest inside storage light protrude through the crack?
This is hard to explain or describe via words, without pics.
My 2010 E had two interior rubber trim pieces on each side of the inside of the "wishbone" center console/armrest doors, that prevented any light from peeping through. On my 2011, one of the doors on said console seemed a little more loose than the perfectly stiff other side (when closed), which allowed it to be poorly fit enough to let out some of the bright LED lighting from inside of the console (the light in there is always on when the cars lights are on), which is a huge eyesore at night, and makes for poor fit & finish that is otherwise uncharacteristic on the W212.
I took it to my Dealer and showed them what I was talking about (pressing down on one side of the wishbone door, to prove that it was loose, and turning on the lights, to prove that the doors did a poor job of sealing, therefore the inside light in the storage compartment protruded through).
They said that M-B forgot to include a rubber inside strip on the passenger compartment-door side, allowing it to not fit snugly, and ordered a new one.
.... The new one came in, and they said that it was the exact same way, and after checking other 2011's, they said that for whatever reason, on 2011's, only one side of the compartment doors have the proper inside rubber seal, while 2010 cars had the seal on both compartment door sides.
Very weird to me. They ended up putting some felt on the inside of the "bad" door on my car, and it's perfect now.
Anyone notice this.... Or even understand what I'm talking about?
Old Jul 18, 2011 | 09:21 AM
golfster's Avatar
Titleist
KA, light does not show through mine when the storage doors are closed. Perhaps an minor alignment is all that is needed.
Old Jul 18, 2011 | 09:24 AM
alloutmk23's Avatar
2011 E350 4-Matic Sport
The compartment doors on my 2011 are not loose, although the light does protrude through like you said.
It's not noticable unless your head is directly above the center of both doors. But It's not like it peers through the cracks and illuminates the cockpit. Dosent bother me.
Old Jul 18, 2011 | 09:47 AM
K-A's Avatar
K-A
Interesting. Problem is, the 2010's had both properly sealed doors, that wouldn't show any light. If you open the doors on your alloutmk, you'll see that the driver side door has a rubber seal going around it, allowing for a tighter fit, and for no light to show through. I found it bizarrely crude and horrid looking when I'd hover my head over the console, and actually get a slight glimpse of what I have inside there, due to the open crack, and the LED light inside showing off what's in there.
Why they'd downgrade this from the 2010 car, is beyond me? I'm assuming the parts supplier made a mistake or something, and M-B assumes that nobody will make a fuss, enough to Warrant a costly DTB.
FYI, to fix it, glue some felt, or rubber in the proper places, and it's back to normal.
Old Jul 18, 2011 | 02:39 PM
Tjdehya's Avatar
2023 AMG EQS
I did notice this very issue when I picked up my second W212. I never went back to the dealer because of it because I was already tired of seeing them after dealer with the problem with my first W212.
But yes my light also shines through the center console.
Old Jul 18, 2011 | 02:44 PM
K-A's Avatar
K-A
Interesting. I'm surprised more people haven't complained about that.
I find it to be extremely crude and unfinished for such a car. Hell, if my Chevy Malibu had that, it would drive me nuts and give me the notion of a poorly constructed/designed interior ambiance.
Old Jul 18, 2011 | 02:46 PM
K-A's Avatar
K-A
If it bothers anyone enough, I'll take pictures of what my Dealer did, to give you an idea as to how to fix it. It brings the console up to the 2010 cars specs, with a tight right-side door that doesn't move or wiggle in the least, and doesn't let out any light (and doesn't let you catch a glimpse of what is inside the console storage compartment, when the doors are "closed").
Old Jul 18, 2011 | 03:01 PM
hyperion667's Avatar
2012 CLS63
hmmmmm......I haven't been in my car at night (black time) since.......geez, before DLST......
