Sponsored by: CARiD
Old Jun 24, 2015, 07:36 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Wheels and Tires
Print Wikipost
Accuracy of In-Dash Tire Pressure Monitor?
Old Aug 10, 2011 | 02:22 PM
marka5083's Avatar
e350
I wonder if others have experienced a discrepancy between the in-dash tire pressure monitor and actual tire pressures.
I find that the monitor is consistently off by 3-5 PSI even after resetting the monitor several times.
However, it may be that this is within normal operating parameters as the monitor may not be designed to be precise, but to only be a backup/failsafe to accurate manual monitoring.
Would be interested in other opinions.
Thanks.
Old Aug 10, 2011 | 02:48 PM
Dooty's Avatar
E350 Bluetec
Real Close
2011 BlueTec. I've filled the tires to recommendations. Shortly after leaving the garage, 3 are the same as the tire gauge. One is always one pound low. Pressure builds quickly after one mile but the readings are consistent. I think mine is very accurate!
Old Aug 10, 2011 | 07:46 PM
peeta123's Avatar
C220, E350
i cant even get a reading in my car
it just says that the tire pressure is ok
Old Aug 10, 2011 | 11:22 PM
RSIKR's Avatar
2014 W212 E350 4M
Thanks.
If you adjust the tire pressure you have to drive the car for a while before the TPMS can read the pressure. By this time the pressure can increase from heat, both from the outside temperature, brake friction, flexing of tires etc.
Another consideration is the accuracy of your tire gauge. Some of the old style pencil gauges can be questionable. A good dial or digital gauge is an asset. When the TPMS achieves a reading stop the car and compare it to your accurate gauge.
I believe my TPMS is very accurate.
Old Aug 11, 2011 | 07:32 AM
hyperion667's Avatar
2012 CLS63
I think mine is accurate too......and it's less than a mile for the numbers to display....
Old Aug 11, 2011 | 10:58 AM
BenzMan369's Avatar
2012 E350 Coupe
Some additional info:
While the TPMS should provide a reasonably accurate reading of actual tire pressures, it's my understanding that's not its primary function. It exists to warn you of a significant drop in tire pressure - based upon the "normal" tire pressures you have set it for.
If you adjust your tire pressures, you must do a TPMS Reset immediately thereafter. When the tires heat up with driving, the TPMS will then use the Reset values as "normal" to evaluate any significant drop. If you don't do a Reset, the warning system will be inaccurate.
Further, the TPMS system is calibrated to be accurate at sea level. If you live in a high altitude location, the system again may not be accurate.
MB recommends not relying on the TPMS alone for accurate pressure readings. They should be verified with a reliable manual gauge.
As RSIKR notes, many things can affect pressures. I have found that persistent driving with the sun beating down on one side of the car on a hot day raises the pressures on that side in comparison to the other.
Old Aug 11, 2011 | 11:04 AM
BenzMan369's Avatar
2012 E350 Coupe
That is one gorgeous hunk of metal Hyperion!
Happy motoring.
Old Aug 11, 2011 | 01:12 PM
dfordham's Avatar
2014 E350, 2012 SL550
I live in southern New Mexico at almost 4,000 ft. elevation. I just used my TPMS for the first time this morning (just got the car) and it is within 1 psi of my tire gauge. So it seems that elevation doesn't have much effect, at least the elevations where most people live and drive.
Don
Old Aug 11, 2011 | 01:23 PM
MBTAZ's Avatar
2017 CLA & 2017 GLE350
I checked & reset my Complete TPMS (factory SDS, TPMS tool & certified Tire Pressure Gauge) at sea level & 68 f found 1 PSI off..
If your not using a certified tire pressure gauge you can be off even more..
As previously stated & MB / US law it's for safety not accuracy almost like depending on your outside temperature display for accuracy when it's only to check for frozen temperature & ice..
Old Aug 11, 2011 | 01:50 PM
RSIKR's Avatar
2014 W212 E350 4M
The TPMS is a great investigative tool. For example you hit the edge of a pothole, concerned about a pressure loss, check the TPMS before the low pressure warning alerts you. The most important factor is consistency. If there is a substantial difference from right to left side after they were inflated to the same pressure I would be concerned. As discussed the pressure increases when you drive and is related to ambient temperature. As BenzMan 369 pointed out, the sunny side of the car on a hot day can be a pound or two higher.
Old Aug 11, 2011 | 03:17 PM
YYZ-E55's Avatar
MY17 E43 Matte Selenite/Macchiato Beige, MY16 GLE350d Tenorite/Crystal Grey, MY17 B250
Most Canadian MBs use a passive tire pressure monitoring system (code 477) which uses the wheel speed sensors to determine if a tire is low. A low tire means increased rolling resistance, which is interpreted by the wheel speed sensor.
The active system (code 475) is mandated in USA and has a wireless pressure sensor in each wheel (as part of the valve stem). This is why you don't see an actual pressure value displayed in the instrument cluster.
Old Aug 11, 2011 | 03:30 PM
rovermark's Avatar
2011 E350 4Matic Estate in Mystic Red
Originally Posted by YYZ-E55
Most Canadian MBs use a passive tire pressure monitoring system (code 477) which uses the wheel speed sensors to determine if a tire is low. The active system (code 475) is mandated in USA and has a wireless sensor in each wheel. This is why you don't see an actual pressure value.
YYZ-E55:
It says that it is monitoring Run Flat tires, but as far as I know, Canadian models are not equipped with Run Flats. Correct?
Also, if I change a tire myself (lets say a flat tire), will I have to go back to the dealer to have the system readjusted? Does it work through a remote wireless sensor in the wheel?
Old Aug 11, 2011 | 03:44 PM
YYZ-E55's Avatar
None of the Canadian 212 E's have run-flats installed from the factory. I'm not sure where it indicates the tires are run-flat?
You do not need to visit the dealer. You can reset the system from the instrument cluster and it will re-calibrate automatically. There is no sensor in the wheel on Canadian models.
Old Aug 11, 2011 | 05:47 PM
EmE247's Avatar
Current: 2011 W212 Previous: 2008 W211 2006 550 2001 Rover 1997 W210
My TPMS monitor is on at all times in my car. Because of the crappy potholes + 19's/less rubber + somewhat crappy suspension in the W212, it's the first thing I look at when something doesn't feel right.
Not really sure what other functions might be useful in its place anyways. Need 2 read da manual someday.
Old Aug 11, 2011 | 08:34 PM
rovermark's Avatar
The message when checking the gauge screen states "Run Flat Indicator Active" (the same gauge that shows you the car info and allows you to reset it).
Old Aug 11, 2011 | 10:08 PM
YYZ-E55's Avatar
Ahhh - yes, as in "flat tire indicator". Good old genglish
Old Aug 11, 2011 | 11:14 PM
peeta123's Avatar
C220, E350
thats a good thing since i dont have to deal with the sensor batteries later
Old Aug 12, 2011 | 12:21 AM
Live Oak's Avatar
E550
Sensor batteries?? I thought they were powered by the motion of the wheels.
Old Aug 12, 2011 | 06:13 PM
marka5083's Avatar
e350
FOLLOW UP
OK, so after purchasing a better air pressure gauge, it turns out the the TPMS is very accurate. Those gas station gauges are for s#$t as well, I have learned. From now on I'll trust the MB and my better gauge.
On a different note, just drove ~350 miles on the highway between southern and northern CA and I have to say, driving the E350 really brings a sense of pleasure to driving long distances. Wow.
Old Aug 12, 2011 | 09:41 PM
K-A's Avatar
K-A
Porsche Macan S SportDesign / Ex M-B's: 11 & 10 & 06 E350's, 02 S500
Indeed, this car is the king of long distances. It's truly an art! I've driven many long distance miles in this baby and I couldn't think of a better car engineered for such drives.
Old Aug 13, 2011 | 03:36 PM
220S's Avatar
Porsche 991S, Cayenne S, 1972 BMW 3.0CS E9 Coupe
Seriously? There's no better car out there engineered for long distance driving? The E Class is the only one?
Old Aug 13, 2011 | 04:47 PM
El Cid's Avatar
Veteran: Army
2010 E350 Luxury Sedan, Engine 272 (V6)
Mine is about a pound different from tire gauge I use. Sometimes, some tires will match gauge and a couple won't. Have two gauges and they usually match each other. Interestingly, if leave TPMS on, TP's will change more in some tires than others and then maybe be same for all four again later.
Old Aug 13, 2011 | 07:31 PM
K-A's Avatar
K-A
Where did I say that it's the only one? Lol. All I'm saying is that this car is engineered for long distance drives, and I can't really think of many that I'd rather be in on said long distance drives. This is taking into account safety, comfort, stability, interior ambiance, features, etc., etc.
Old Aug 14, 2011 | 01:56 AM
220S's Avatar
"...and I couldn't think of a better car...."
"...and I can't really think of many that I'd rather be in......"
That's better. Sometimes I think you're getting too drunk off the MB KoolAid, so I have to step in to keep you in line once in a while.
Old Aug 14, 2011 | 08:00 AM
2012 CLS63
haha!
