HID's installed
HID type bulbs
Benefits of HID
Why you shouldn't retrofit
Daniel Stern isn't some fly-by-night internet expert but, often to the chagrin of NHTSA, is considered to provide accurate information.
Finally, here is an excerpt from a NHTSA document that directly applies to you and the individuals who installed those illegal bulbs.
"Because replaceable light sources are, by regulation, designed to be non-interchangeable, it would not be possible for an HID headlamp conversion set to meet the standard’s photometry requirements for an original equipment headlamp system using a halogen light source, so the replacement lamps could not be sold for this purpose. Furthermore, a headlamp dealer or motor vehicle repair business could not remove the original halogen headlamps and install HID replacement headlamps without violating 49 U.S.C. 30122. That section prohibits manufacturers, distributors, dealers, and motor vehicle repair businesses from making inoperative equipment installed in accordance with a Federal motor vehicle safety standard."
Now you why it isn't a good idea to install this stuff on your $50k+ car. What you decide to do is clearly up to you but you know the possible consequences. Be very careful when returning to a dealer for service as they may consider this lighting as a contributing factor to any electrical or electronic failure and could therefore justifiably refuse warranty service on any electrical or electronic failure.
You might not like what I'm saying, but everything I've cited is fact, not internet rumors.
Oh, and these types of installs are known to melt wiring harnesses.
It is obvious from miles away that those are not OE bulbs/housings even if the color temp is similar. Your lights will fail inspection in any state that has inspections and yes, they are illegal.
CEB does make a valid point, however we are not some ricers that install $20, 12k HID kits. He tried inform me of this on my last HID thread (appreciate the warning), however I'm sure that people who can afford a 60K vehicle are smart enough to install the correct kits that will do the job.
I installed my M-Tec 6k hid kit last month and it looks amazing. The difference is night and day. My kit is designed specifically for the W211 E class, however it does the same job on my W212.
My projectors are on the factory level setting and luckily my buddies were over to help me test them out. I had them all pass my vehicle down my long street and none were blinded. Nor have i had any drivers high beam me...ever.
You guys must all be special - but not in a good way.
Make no mistake about. The "brighter" image you think you see is an optical illusion because of the excess stray lighting thrown on the ground in front of your car. The only way to get any range is to adjust the assemblies in such a way that must blind oncoming traffic.
I may not be an expert on many things, but I've forgotten more about lighting that the entire population of this forum will ever learn (inless Jeff from my office is here - is that you Jeff?)
I don't care if you guys want to stick candles into your headlight assemblies, but don't try to make anyone believe that you get better lighting from sticking an HID bulb into a halogen housing. Just admit that you're peeved that you didn't buy a P2 equipped car and now want to feel cool with the whiter lights - but remember - you've degraded your vision by doing so.
I challenge any of you to find an article by a reputable institute, scientific organization or government agency that demonstrates any benefit of placing HID bulbs into halogen housings. That person gets a nice gift card from me. So far, I'm the only one to have provided overwhelming evidence why it is a bad idea.
It is so much easier to attack the messenger than it is to try to find rebuttal evidence that doesn't exist. That's the way that schoolyard bullies play.
Him making a stupid comment like that is basically going against hundreds of forum members, and thousands of people who have installed aftermarket Hid's.. witch im sure would laugh at him just like i am.
