Message to remove plug and insert key to start
This problem was in my 2012 E350 with 2,000 miles. Has anyone else had this happen?
But seriously, I didn't see the use for it either - until I had it. Now I wouldn't want to be without it.
I say this as the guy who does most of the daily needs shopping and am frequently in and out of the car 4-7 times in one trip.
And then there's the female half (more like 75% of the relationship). She loves not having to search through her bottomless pit of a purse for keys. She has a lawyer on standby if I ever buy another car without the feature.
I think there are other threads elsewhere here with pretty much the same sentiments expressed in many posts.
To each his - or her - own, of course.
-Matt
i've been using keyless entry & push-button start in other cars since 2005 and never had any issues with the systems. this isn't some crazy new technology that no one has figured out how to do right yet. it's clearly a defect of this particular implementation. hopefully it's something simple like a bad part from a supplier that can be replaced.
-brent
unfortunately the P2 forces the option...i had to have the p2 for the Bi-Xenon headlamps with Active Curve Illumination because i am tired of driving in the dark (my 530i had the lights and the car i am trading in did not - night and day difference - no pun intended).
i was not really happy to get the Electronic Trunk Closer either....talk about something to go wrong that would really be bunk if you could not get into your trunk.
if anyone from mbusa reads this forum more a la carte please on special order configurations.
The trunk closer is simply a convenience. You can pull the trunk closed or use the switch in the cockpit to close.
Yup, there is no need to get the key out of your pocket and it's a wise idea to leave it there because you may inadvertently put your key in your trunk and press the button , you know rest of the story
This!
.Rest of the story is the trunk will pop right back open. It will first close by the closing motor but immediately opens up again if the key is in the trunk.
I have actually done this a few times by an accident and every time the trunk opened without locking me out.
They don't call it smart key for nothing then lol
.... To reiterate, even with P2, your key DOES HAVE a home, and if you don't want it to be your pocket, then M-B allows you the option to use the car "normally".
For the trunk closer, it is also manually operating if you want it to be, so even if the motor goes out, you can use the trunk normally.
.Actually, I wanted a auto closing trunk and in order to get that option I must have got keyless go
