Sponsored by: CARiD
Need Help To Camber My E350
Old Sep 30, 2012 | 12:53 AM
snake529's Avatar
w212 E300
Hi All,
i have a complicated issue regarding my car.
I have a camber kit for my W212 E350 2012, i install one side, but i discovered that there is headlight level sensor in one side
I dont understant how people install their camber kit without refer to that point !!!! maybe US w212 versions runs without this sensor
In the moment if anyone here can guide me for any company can make a camber kit for W212 with holes to install my OEM light sensor i will be happy really.
i am really disappointment
Old Oct 1, 2012 | 09:53 PM
GermanCars's Avatar
2020 E450 Wagon
Exactly what does your "camber kit" consist off? How about some pictures?
Old Oct 2, 2012 | 03:35 AM
snake529's Avatar
w212 E300
Hi bro,
i bought a camber kit its only 2 adjustble arms to replace the OEM arms.
once i replace one i figure out that there is a sensor on one side, the problem now how can i fix the sensor on the new adjustble arm ?
in the pictures tiy will see 2 small bolts mounting in the OEM camber to adjuste the headlight level and signal lights as well.
I think to drill the adjustble Camber Arm but its to thick.
Am wondring if there is any company sell camber kit with Auto Level sensor mounting i will be happy really.
He is the camber kit picture:
he is some pictures of my car undereeth:
Old Oct 2, 2012 | 08:06 AM
clmulli's Avatar
2010 E350 Sport
There is a seller on here that sells cambers for our model. He may be able to provide you some insite. Search camber!
Old Oct 3, 2012 | 12:42 AM
snake529's Avatar
w212 E300
Actullay i bought the camber kit from him lol.
guys any solution please ?
Old Oct 3, 2012 | 09:20 AM
snake529's Avatar
w212 E300
Guy am really need help in this issue !
Old Oct 3, 2012 | 08:20 PM
GermanCars's Avatar
2020 E450 Wagon
Are you sure you are replacing the correct links? The replacement links in the picture kinda look like they could be lower links. I will look at the Mercedes EPC tomorrow to confirm you are headed in the right direction.
If you are replacing the correct links, you could fabricate a plate that the level sensor would bolt to and have the plate welded to the link at the proper location.
Welcome to the world of "bolt on-fits like a glove" aftermarket kits. After a couple dozen examples of this kind of B.S. one starts to get leery of aftermarket stuff. It's almost a surprise when something actually bolts up and works like it is supposed to without some kind of modification or "adjustment". Like the rear spoiler that I got for my SL from a vender on this site. The fit was so bad I just threw it in the trash. It would have cost more to have it fixed than what it sold for in the first place.
Old Oct 8, 2012 | 03:33 AM
snake529's Avatar
w212 E300
i replace the correct links bro
just wanna know if there is company provide a set of cambers with sensor holders ?
Guys who install camber kits please advise >>>>
Old Oct 8, 2012 | 07:28 AM
hyperion667's Avatar
2012 CLS63
sounds annoying........so many issue's come with the lowering business.......
Old Oct 8, 2012 | 08:59 AM
snake529's Avatar
w212 E300
i really suprised how they selling Camber Kit without understand the issue of headlight auto level sensor in one of OEM camber links
AM REALLY SUPRISED
Old Oct 15, 2012 | 10:19 AM
GermanCars's Avatar
2020 E450 Wagon
I finally got around to putting our E550 up and have a look. As the 550 has Airmatic, we have a sensor on BOTH sides. It amazes me that someone will start selling a kit without a whit of research as to the requirements of different models.
My suggestion of welding a plate to the link(s) still sounds viable. Welcome to the world of "tuning".
Old Oct 15, 2012 | 10:22 AM
clmulli's Avatar
2010 E350 Sport
Ouch Welding sounds painful. I would ship back for full refund. Should have come with instructions. Much success Snake!
Old Oct 15, 2012 | 10:36 AM
GermanCars's Avatar
2020 E450 Wagon
Has the vendor not responded to your contacts?
Without having the original link and the replacement next to each other I couldn't say, but you might be able to drill one hole for the locating dowel and another for the attachment bolt for the linkage mount instead of welding on a plate. The issue is whether the there is enough material at the end of the threaded link for a hole to be drilled and threaded without interfering with the end of the threaded part of the outer joint.
