Sponsored by: CARiD
Removing The Battery-Bad Idea?
Old Jan 1, 2013 | 09:31 PM
listerone's Avatar
2018 BMW 540d
I'm going to be away for over a month (January/February) and am considering the above action in order a) to avoid theft and b) to place the battery indoors hooked up to a trickle charger.I know that doing so will require a "reprograming" of the central computer...transmission,etc...and I'll lose seat settings,radio settings,etc.But am I missing something important,or even semi-important? For example,will the music stored on the hard drive disappear? TIA!
Old Jan 2, 2013 | 09:45 AM
petee1997's Avatar
...24 GLE53
If only gone 30 days, you are wasting your time. Lock the car and the system goes to sleep. I leave mine in that mode every winter for up to two months with no problems.
Old Jan 2, 2013 | 11:22 AM
RSIKR's Avatar
2014 W212 E350 4M
Real bad idea. I too have left the car sleep for weeks with no issues.
Old Jan 2, 2013 | 03:29 PM
ImInPA's Avatar
2012 S350 Bluetec 4Matic, Diamond White, P2
You do not have to remove the battery to trickle charge it. Just follow the instructions in the owners manual and use the jump start connections. Also, make sure you use a charger that is compatible with AGM/VRLA batteries.
Old Jan 2, 2013 | 05:33 PM
listerone's Avatar
2018 BMW 540d
What I failed to make clear is that I don't have access to a garage or an electrical outlet....I live in a condo.The trickle charger I have is an official BMW charger which,I read,is suited for AGM batteries.
Old Jan 2, 2013 | 07:57 PM
Arrie's Avatar
Other than to prevent the theft battery removal is unnecessary. It will not go down in a month, probably not in two months and removing it for long time will certainly cost extra to get the car running again. And if it goes down too much to start the car again it is just a simple jump procedure to get it going again.
Music on the HDD should not be lost.
For preventing the theft, couldn't you just boot the car?
Old Jan 2, 2013 | 10:01 PM
YYZ-E55's Avatar
MY17 E43 Matte Selenite/Macchiato Beige, MY16 GLE350d Tenorite/Crystal Grey, MY17 B250
I'd rather come home to a missing car than a car that was smashed up but still sitting there! It's tough to steal a Benz these days short of flatbedding it or obtaining the keys.
Worse would be throwing out your back trying to get the battery out!
Old Jan 3, 2013 | 06:00 AM
theraven333's Avatar
Mercedes E350 CD Iridium silver convertible 2010
Hi ! If it is the Ctek battery charger(BMW own brand them) then it is an intelligent battery charger and is suitable for AGM batteries, as many BMW's have these types of battery including my last 6 series!!!!
Old Jan 3, 2013 | 09:54 PM
Mbenz260e's Avatar
2022 E450 Prior:2021 S580 2012 E350BT, 2013 GL350BT, 2009 ML320BT, 2006 E320CDI, 1987 260E
I really wouldn't worry too much. My mother has a 2004 CLK she has left 3 months (unplanned extended overseas trip) and it started right up, even with an 8 year old battery. I think you may cause more issues than you are avoiding.
Other option, find a board member in the CT area to drive it for you
Old Jan 4, 2013 | 02:10 PM
listerone's Avatar
2018 BMW 540d
No,that can't happen.It's a diesel and several years ago I was officially certified as being the only person in the Nutmeg State who's qualified to drive a diesel automobile.
Old Jan 4, 2013 | 02:12 PM
listerone's Avatar
2018 BMW 540d
Yah,I'm almost certain that my "d" had an AGM battery and it worked fine.And it is a BMW brand,featuring the BMW logo and having been bought
at a BMW dealership.Too bad this charger can't be the solution to my situation.
Old Jan 4, 2013 | 02:16 PM
listerone's Avatar
2018 BMW 540d
Thanks much to all who replied. I think I'll just keep the battery hooked up and hope a) that the battery survives and b) that mBrace does,in fact,notify me if any attempt is made to steal the vehicle.It's worked in the past when I accidentally set off the alarm system so it probably would do so again.
Old Jan 28, 2013 | 01:32 PM
mleskovar's Avatar
'17 Jaguar XF
I just read that a healthy car battery with no drain loses only 5% charge per month so you should be good to go.
Old Jan 30, 2013 | 06:01 PM
telemakhos's Avatar
E350 4Matic 2011
I left my car for over a month - no issues. I too would leave the battery in.
Old Jan 30, 2013 | 09:10 PM
rufmb's Avatar
2013 Mercedes E350 Luxury
So why would MB sell a trickle charger accessory?
Old Jan 31, 2013 | 08:34 AM
ImInPA's Avatar
The battery in the E350 Bluetec is not a true AGM. It is actually a Valve Regulated Lead Acid battery (VRLA). It does take the same charge cycle as an AGM battery would.
