Sponsored by: CARiD
Facelift steering wheel in w212
Old Jan 25, 2013 | 08:46 AM
CTDK's Avatar
W221 S550L, W212 E250CDI Wagon
Sorry if this has been up proberly a million times, i tried using the search function but couldnt really find anything...
I just bought a 2011 W212 and I want to put the 2013 AMG P30 steering wheel in the car, I did the same thing in my W204 that ive just sold, and i needed to change the steering column electronics in order to get the light in the buttons to work..
however in my W212 there is automatic transmission, so ive bought the steering wheel with shiftpads, is it just plug and play maybe some coding, or does the steering electronics needs to be replaced here aswell ?
Old Jan 25, 2013 | 12:38 PM
BenzV12's Avatar
W212 FL
Hey, you may wanna take a gander at this topic :
https://mbworld.org/forums/e-class-w...el-change.html
No pita but once you plug and play is done as soon as you start the engine you are gonna see ----------- , don't freak out just press the back button (top left hand side )
My service reminder also converted to days rather than mileage but after a 2nd removal of airbag with the cables were still attached then it went back to kilometers option which is cool lol
Take it easy ,enjoy
Old Jan 25, 2013 | 12:44 PM
CTDK's Avatar
Cool, i have no trouble removing it, i work with cars everyday but great that its just plug and play, i was worried i has to exchange some more parts like in my C class
Old Jan 25, 2013 | 03:19 PM
Yosheego's Avatar
2011 E550
that's a nice steering wheel!
Old Jan 25, 2013 | 07:01 PM
xolinlevh's Avatar
2011 E550 4Matic
I have an 11 also and want the new wheel, where did you get yours?
Old Jan 26, 2013 | 05:34 AM
BenzV12's Avatar
W212 FL
Mine is thru authorized MB accessory shop , however I have seen many cool ones in ebay as well as carbon fiber trims
Dealerships should be able to proved you with some details
Old Jan 26, 2013 | 09:11 AM
threeMBs's Avatar
Only MBs - the best or nothing
BenzV12, could you please provide part numbers for both the steering wheel and the airbag.
Old Jan 26, 2013 | 03:24 PM
BenzV12's Avatar
W212 FL
This is part # to mine :
Here's the part # A172 460 48 03 9E38
Another number 57554/0028 LENKRAD Steering Wheel
This number A172 suggests me that this steering wheel is made for SLK 55 AMG
Bear in mind, OP's has a different version and if your stock steering wheel has some options such as heating,vibration this part # will not become compatible with yours
Sorry, I don't have airbag # but anything with that shape can fit easily . I also swapped the aluminum trim (AMG Logo bottom) but have not updated the topic I posted
Old Jan 26, 2013 | 08:00 PM
Arrie's Avatar
I don't mean to raise bad blood here but wanted to give my opinion about this.
A steering wheel like this looks cheap in a car like W212 in my opinion. It looks like some NASCAR wheel which is made cheap as it does not need to do anything else than turn the wheels. Need to have a real sports car with a wheel like this. And again, this is my personal opinion.
I drive a E550, which based on power, qualifies as a sports car at least compared to some other makes but I would never have a steering wheel like this in it. It is far more impressive to have someone sit in it and notice the power of the engine when the inside and out looks not that sporty.
That raises the question in the passenger's mind of how fast are those Mercedes cars that really look sporty...
Old Jan 27, 2013 | 10:06 AM
petee1997's Avatar
...24 GLE53
My two current MB's have the AMG package with the sport steering wheel. It is very comfortable to drive with the thumbs at ten and two. It makes a good match with bright aluminum pedals and the AMG body cladding and wheels.
On the negative side, I lost the standard heated steering wheel. It is not available on this steering wheel. Due to our climate, I would trade for the regular wheel.
Old Feb 6, 2024 | 12:45 AM
Sashki81's Avatar
2011 Mercedes E550 4-Matic
so did you need to replace the steering column or was it plug-and-play? The reason I’m asking is about the same exact steering wheel and I have a 2011 E550 and I wasn’t sure if I can just install this new steering wheel and use my original steering column. Any help would be appreciated before I do the swap. Thanks guys.
Old Feb 7, 2024 | 02:18 AM
BenzV12's Avatar
W212 FL
Mine was plug and play . You can also use W177 A Class Sedan steering wheel but it may need coding
