Sponsored by: CARiD
2013 E350 front left engine noise
Old May 20, 2013 | 11:35 PM
2006_C350's Avatar
2010 C300 & 2014 E350
I have a 2013 E350 with about 6,200 miles. Every time I start the car and begin moving forward, within the first 5-10 seconds the car makes a grinding/clicking noise from the front driver's side and you also feel some kind of notchy rattling in the foot area underneath the dash. This noise appears to be coming from the front left of the car and moves into the driver's side foot area. This can be duplicated every time you turn off the car and turn it back on. This only happens when you first start up the car and start moving.
Has anyone experienced this on a 2012 or 2013 E350?
Old May 21, 2013 | 12:46 AM
jmatero's Avatar
2013 E350 P1, Sport, Rear Spoiler
Just guessing but most car ABS systems test cycle every time the car is started and then moves forward.
Old May 21, 2013 | 12:54 AM
ImInPA's Avatar
2012 S350 Bluetec 4Matic, Diamond White, P2
What you describe sounds like the anti-lock brakes going through there startup procedure. It can be felt in the floor and/or brake pedal I think you have nothing to worry about, but a quick trip to the dealer will verify that. Good think it is easy to reproduce.
Old May 28, 2013 | 11:34 PM
2006_C350's Avatar
So no one has experienced this? Really hope someone would chime in because the car is still at the dealer and it's been two weeks already...
Old May 28, 2013 | 11:41 PM
jmatero's Avatar
I think we all experience this. See the 2 posts above.
Old May 31, 2013 | 12:34 AM
2006_C350's Avatar
dealer says it is the ESP startup procedure...
Old Jun 4, 2013 | 10:30 AM
2006_C350's Avatar
I have tested out other E350 and they just have the slight clicking sound. Mine follows the click with "something" that sounds like something is engaging and then a few rattles in the gas pedal area...
It's obvious mine is alot more noticeable when I checked with other owners.
Old Jun 6, 2013 | 11:51 AM
2006_C350's Avatar
I posted a youtube link so you guys can hear the sound. You can hear it around the 5-9 second mark.
