Sponsored by: CARiD
Sticky breaks on cold start (2012 E350)
Old Sep 5, 2013 | 09:32 PM
Ajax Lesser's Avatar
2012 E350
Unhappy Sticky breaks on cold start (2012 E350)
Hello,
After my last service, I started noticing something strange with my break pedal.
Only after COLD starts, the break pedal "sticks" for the first 1/4 or 1/8 of an inch during the first few depressions. After the car is in motion, after I depress the breaks 6+ more times, the break pedal depression is smooth, same as it always has been.
Found two similar threads with this odd issue from other forums:
https://mbworld.org/forums/sl-class-...al-sticks.html
https://mbworld.org/forums/w218/4583...edal-feel.html
Anyone else encountered this issue?
Thanks!
Old Sep 5, 2013 | 09:36 PM
alanme123's Avatar
2012 E350
Never heard of this happening, but honestly if it has something to do with the brakes I would contact the dealer ASAP.
Old Sep 5, 2013 | 09:54 PM
2012 E350
The issue only repros on COLD starts. I already brought the car in once, the dealer "could not identify the issue". Thoughts?
Old Sep 5, 2013 | 10:06 PM
alanme123's Avatar
2012 E350
Does it actually stick? like with no motion? Or does it just depress slower than usual??
Also, did you leave your car with the dealer over night? That's the only way to really get a "Cold" start on the car. If they check it out right after you bring it to them it won't be a cold start. Sorry if you have already done this, just checking.
Old Sep 5, 2013 | 10:11 PM
2012 E350
The pedal definitely can be depressed. The first 1/4 to 1/8 inch requires a lot more pressure, the rest of the pedal depression is normal pressure.
Analogous to poking a hole in a piece of paper using a pen. First bit there is tension, after the hole is punctured, rest is smooth.
Did not leave the car overnight. Thing is, this issue only repros once, twice, maybe three pedal depressions after a COLD start. All of it has to be gauged through the driver's legs .... nothing is "visible" or "audible", thus can't be documented.
Will call the dealer tomorrow to see if something like this can be set up. Thanks for your advice!
Old Sep 6, 2013 | 01:57 AM
alanme123's Avatar
2012 E350
I am thinking maybe its just the brake fluids in the car being too cold? I am just throwing random guesses now and I actually have no idea if that actually causes it. It may lead you to something though?
Old Sep 6, 2013 | 11:20 AM
Arrie's Avatar
Originally Posted by Ajax Lesser
Hello,
Thanks!
Would like to have opinion from some experts here, like konigstiger seems to have access to a lot of documentation about these cars.
I don't know if the brake booster is a vacuum operation or electronic or both. Im thinking that the booster operates from a signal coming from the brake pedal, i.e. there would be a force sensor of some kind at the pedal linkage that gives a signal for the booster to take action. If this sensor gets "sticky" it takes more force for it to see the pedal force and this could be the reason why first pressing the pedal is felt like sticky pedal until force on the pedal is high enough to activate the booster.
If there is such a force sensor I don't understand why MB does not go fixing it as it could be just an adjustment on the sensitivity of the sensor...?
Old Sep 6, 2013 | 11:57 AM
champaign777's Avatar
2010 MB 350i Coupe P2 WD
It maybe you are missing a vacuum on a cold start
looks like some vacuum leak in a brake system and
if it is the case the problem will get worse over time
it is a SAFETY issue , dealer should fix it ASAP
GL
Old Sep 17, 2013 | 05:31 PM
2012 E350
Took it to the dealer again ..... they still were not able to repro the issue.
What's the best way to test whether or not there is an issue with vacuum / brake system? If there was something wrong, would it show up in the error codes log?
Quite disheartening.
Old Sep 18, 2013 | 07:35 PM
mleskovar's Avatar
'17 Jaguar XF
... leave your car with the dealer over night? That's the only way to really get a "Cold" start on the car....
Originally Posted by champaign777
It maybe you are missing a vacuum on a cold start looks like some vacuum leak in a brake system and if it is the case the problem will get worse over time....
If your booster is like mine the vacuum line attaches to one of two connectors on a plastic elbow. The other connector is plugged (maybe for a test/calibration connection?). Check those connections. Does it make any difference how long you wait before depressing the pedal after start?
Old Sep 24, 2013 | 12:15 PM
PeterUbers's Avatar
have a subtle, similar issues on my 2k14 .. not too worried about it, but will bring it up if it becomes more prevalent .. seems like an inherent "feature"
