Sponsored by: CARiD
Hardwire 9500ix - where is switched power in the dome above mirror?
Old Nov 21, 2013 | 06:20 PM
T.H.Carrera's Avatar
2012 w221
I have the "invisicord" and want to tap into switched power in the top mbrace\mirror\light structure and am wondering if anyone has already done this and can point to which cables to tap?
Thanks!
Old Nov 21, 2013 | 06:21 PM
champaign777's Avatar
2010 MB 350i Coupe P2 WD
https://mbworld.org/forums/e-class-c...w-owner-2.html
check post from 39
you need to open overhead light , there are 2 red/ black BIG front wires which you want to use
the beauty of this when your car is going to sleep your radar is going to sleep too
Old Nov 21, 2013 | 06:28 PM
2012 w221
check post from 39
Thanks so much, I owe you one
Old Nov 21, 2013 | 06:33 PM
2012 w221
check post from 39
where can i find that 9500 mounting hardware !!!! How much is it ?
Old Nov 21, 2013 | 06:36 PM
this why we all here dude
to be honest i didn't find much help when i did my , looks like to open overhead light is a big task for many of us
I found the best way is to use 2 mounts from PerformancePackage team
What i did is i merged inner parts from 2 of them ( see these 2 big left right plastic handles ? )
This gives me the right length / flexibility to build one mount connected to the top of our MB mirror
You cant use just one mount as it will be too short ...
Amazon.com: MirrorMountTM Radar Detector Mirror Mount - Escort 9500ix, 8500x50, Solo S3, Redline: Car Electronics Amazon.com: MirrorMountTM Radar Detector Mirror Mount - Escort 9500ix, 8500x50, Solo S3, Redline: Car Electronics
Old Nov 21, 2013 | 06:39 PM
2012 w221
i have always used the included suction cups and some time give out.
So 70 bucks to get it like yours, hmmmmmm.
Old Nov 21, 2013 | 06:44 PM
ya a bit costly , agree
your car , your decisions , i cant watch this crap failing on my dashboard hahaha so i spend some money/time to do it right
Old Nov 21, 2013 | 06:48 PM
2012 w221
You did not mention which wires you tapped ? Do you by any chance remember or have a picture of the ones you tapped into ?
Old Nov 21, 2013 | 06:52 PM
no i dont have picture
on BMW i used only RED one and black is connected to the car body ( roof )
unfortunately this was not the case for MB as i was not able to find (-) on a roof ( maybe it is aluminium ?? dunno )
so i found 2 BIG red(+) /black(-) main wires , you will see them , they are easy to find
i can help you if you post the open overhead light so i can mark which cables i used
I also have voltage up on my 9500Xi and i see from alternator it keeps around 13.2V
when car is running
Old Nov 21, 2013 | 07:15 PM
2012 w221
Uploading pictures now.
Attached Thumbnails Hardwire 9500ix - where is switched power in the dome above mirror?-photo-1.jpg   Hardwire 9500ix - where is switched power in the dome above mirror?-photo-2.jpg   Hardwire 9500ix - where is switched power in the dome above mirror?-photo-3.jpg   Hardwire 9500ix - where is switched power in the dome above mirror?-photo-4.jpg
Old Nov 21, 2013 | 09:06 PM
on first photo second blue connector there are 2 wires red and black
first try them with voltmeter
Old Nov 21, 2013 | 09:08 PM
2012 w221
ok thanks!
You used t tap connector ?
Old Nov 21, 2013 | 09:09 PM
no tap connector , just welded it
dont forget car should not be in sleep mode when checking for voltage ( push the start button minimum one time )
Old Dec 6, 2013 | 12:56 PM
whats up dude
have y able to do it ?
Interesting to see some pictures and study something from y on this topic
Old Dec 6, 2013 | 01:09 PM
2012 w221
Yes I completed it. I made my own "invisicord" using a black telephone cable. Then tapped into the lower red and brown cable on the first big blue connector (that is switched and goes off when car is locked). Tried using a T tap but they suck so did a direct splice and connect.
Old Dec 6, 2013 | 01:39 PM
pictures or it never happened
Old Dec 6, 2013 | 03:01 PM
michael10128's Avatar
2014 E350 4Matic/2011 E350 4matic / 2003 E500 /2000 CLK 430
I was lazy, bought an Add a Fuse, which allows you to take an existing fuse (accessory) and put an additional fuse in the line. I just hid the wires from the Passport from the windshield mount above the dash, under the dash, under the moldings into the fuse panel. cost me like 6.00
Old Dec 6, 2013 | 05:34 PM
2012 w221
fuse panel is in the trunk tho ?
Old Dec 21, 2013 | 10:44 PM
i would like to do exactly what you did…. can you PM me or post the step by step?? Awesome.
Old Dec 21, 2013 | 11:45 PM
GregTR's Avatar
2014 E350 Wagon, 2025 GLC 350e, 2026 E53 Wagon
There are two fuse boxes, one is in the front, right in front of the driver (left) side under the hood just under the windshield wiper and the other one is in the rear in the trunk.
Old Dec 21, 2013 | 11:52 PM
Nanook's Avatar
'18 GLE63S AMG /'19 PORSCHE TURBO S / '09 CORVETTE ZR1 /'14 LEXUS RX350/'16 RAV4 Ltd
Here is how I did my ML63 AMG
https://mbworld.org/forums/new-m-cla...tall-here.html
Old Dec 24, 2013 | 02:29 PM
faz999's Avatar
E350 -2012 W212 4 Matic
I just bought a brand new 950ix $350 from amazon lighting deal received it today
I am looking for anyone in chicagoland to install / hard wire it for me please
Please PM me if you like
I am using Illinois Ipass double sided Velcro
thanks
Attached Thumbnails Hardwire 9500ix - where is switched power in the dome above mirror?-radar1.jpg
Old Jan 12, 2014 | 06:21 PM
mikemem23's Avatar
E350 Coupe
do you have a link to how to open the overhead console to get to the light wiring?
Old Jan 12, 2014 | 06:52 PM
Old Jan 16, 2014 | 06:46 PM
david328's Avatar
2014 e550
hard wire w213 escort 9500ix
I just had a guy come to my home, tap into the under hood fuse box, wire my 9500ix in about 30 minutes. I have a 2014 e class. looks great, no muss, no fuss, 80 dollars. i live in the chicago suburbs.
