Sponsored by: CARiD
Neck-pro removed! Airbag Malfunction!!!
Old Jul 9, 2014 | 11:10 PM
EMLUK's Avatar
Mercedes AG E220 2010 Metalic Silver, Audi A7 Ibis White, Audi Q7 2011 Ibis White
Exclamation Neck-pro removed! Airbag Malfunction!!!
Hi, I'm new around here, not had a Mercedes for too long, actually only had it 3 weeks, and i have ended up fitting aftermarket rear seat entertainment (Xtrons 9") for the younger ones.
However after i wired up the rear screens, routed the power from the 12V power supply, removed the pop-out mechanism and wired them into the back of 12V outlet, this leaves full functionality of the outlet, I was happy and turned on my ignition to find that i had both left and right airbag malfunction, I know this is because i removed the neck-pro headrest and disconnected the yellow sensor. Is there anyway to trick the car into thinking its still plugged in?
And with the OME Headrest removed and malfunction showing, will this disable all my airbags? I am a little worried, if all my airbags get disabled then i will put the OEM's back in straight away? This is my greatest concern that all my airbags will not work because of the malfunction
Any advice is greatly appreciated! Thanks!
Old Jul 10, 2014 | 10:11 AM
CEB's Avatar
CEB
1953 300 Adenauer, 1971 300 SEL 6.3, 1975 600, 1978 450 6.9
That's actually unknown and there is no real way of determining how your airbag system will function without crash testing the car.
All the systems are integrated and a failure of one will cause some sort of a failure of the rest of the system.
The aftermarket entertainment system is not suitable for your car and you should take it back to the store that sold it.
I think there is an iPad attachment that works with NeckPRO but you may need to research this further. Remember that the headrest is an integral part of the safety system intended to keep your head in the appropriate position during a crash.
Old Jul 10, 2014 | 03:33 PM
RNBRAD's Avatar
W211 E320 & W212 E550
MB has a retrofit system that's pretty nice. Kinda pricey but you won't have these issues. These cars are full of safety features so it takes some investigation before doing these things. Not your typical automobiles.
Old Jul 10, 2014 | 03:59 PM
CEB's Avatar
CEB
Correct. Pricey is certainly better than sacrificing safety.
Old Jul 10, 2014 | 04:00 PM
weinschela's Avatar
'14 E350 wagon; BMW G12 (2020) G01 (2019)
Disabling integrated safety features for the sake of rear seat entertainment does not sound like a good trade-off to me.
Old Jul 10, 2014 | 04:50 PM
RA72825's Avatar
With so many handheld devices available for entertainment today, why would anyone actually install something into any car?
Old Jul 10, 2014 | 05:10 PM
EMLUK's Avatar
Yeah, you're right, I've taken them off and am looking into just some detachable/portable ones, I found some with the Android system and they look pretty good, + they wont interfere with the airbag system etc.. Id rather be safe than be crumpled with a movie playing in the back
Thanks again - Appreciate it!
Old Jul 10, 2014 | 10:11 PM
AudiA4Turbo22's Avatar
'03 A4 2.0 Stroker, '14 E63 S AMG, '10 E550, '10 S550, '03 C240
You can trick the system by installing resistors at the ends of the yellow plugs. This tricks the system into thinking the neckpro system is still there.
Old Jul 11, 2014 | 04:50 PM
CEB's Avatar
CEB
Right. Are you willing to risk the OP's life on an untested trick? Sure you are since it isn't your life.
Whenever a system is compromised, there is no way of telling how the rest of the system will react. Sure, the resistors may turn the light off but what proof do you have that the rest of the system will work as intended?
I'll bet that whoever designed that workaround didn't crash test the car to make sure the rest of the system still functions as intended - and that is the only way to be sure.
Old Jan 6, 2021 | 12:54 PM
Paul Shalom's Avatar
E400 W207 C320 W203
Have you done this personally? I've seen some articles that say the common resistor trick/bypass doesn't work for Neck Pro.
Old Jan 6, 2021 | 11:05 PM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
This post is from 2014, so I doubt you get an answer.
Old Jan 6, 2021 | 11:06 PM
E400 W207 C320 W203
True. Thanks.
Old Jan 6, 2021 | 11:09 PM
LILBENZ230's Avatar
Originally Posted by Paul Shalom
True. Thanks.
I would not recommend trying to trick any part of the W212 SRS system, though, FWIW.
Old Jan 6, 2021 | 11:14 PM
E400 W207 C320 W203
Mine is a 2015 W207 E400. I did a resistor bypass on the knee airbag and front seat belts. Worked great. W212? I'm sure lots of people have done it.
Old Jan 7, 2021 | 07:04 AM
LILBENZ230's Avatar
Why would you do this exactly?
Old Jan 7, 2021 | 07:26 AM
E400 W207 C320 W203
I purchased it remotely from an auction in another country. It had a hit to the front passenger side and a few error codes that I had to deal with before I could import it. This was the quickest and least costly route until it gets to me. Then I could do all the fine tuning.
