Sponsored by: CARiD
Should the light switch surround be illuminated?
Old Dec 9, 2014 | 04:48 PM
Caesium's Avatar
E350
Just a quick question, the lightswitch on my E350 cab only has illumination on the actuator, not on the surround where the legend is. Is this intended behaviour?
Can someone look at theirs and confirm?
Cheers!
Old Dec 9, 2014 | 04:59 PM
RA72825's Avatar
nope
Old Dec 10, 2014 | 03:17 AM
Caesium's Avatar
E350
Nope it should be illuminated or nope it should not be?!
Old Dec 10, 2014 | 09:31 AM
noka's Avatar
'24 Porsche Macan
The way I interpreted it:
Q: Is this intended behaviour?
A: Nope.
Meaning, what you observe is not normal. I'm not sure how mine is at the moment.
Old Dec 10, 2014 | 01:33 PM
C230Brit's Avatar
2010 E550 Coupe
Hi Caesium,
On my 2010 Coupe, the light surround does not light up (showing the legend).
This has been the same on my previous two Mercedes too.
I always thought it was odd that it does not light up, since typically, I would like to see the legend at night not in daylight!
Hope that helps.
Rich
Old Dec 10, 2014 | 05:49 PM
Caesium's Avatar
E350
Cheers Rich, thats made me feel a little better to know its not faulty even though its an odd design!
Old Dec 12, 2014 | 01:21 AM
Alex.currie44's Avatar
2009 SLK55 AMG. & 2022 GLA250 4Matic
Just checked my 2011 E350 wagon. Only the switch itself lights. Not the surround.
It is really low level lighting as well. With the instrument illumination turned fully up - which I never do - it is not all that bright.
Hope that helps.
Old Dec 12, 2014 | 09:29 AM
RA72825's Avatar
Sorry. I'm on a ski trip. My answer was to your direct question. As said this has been this way for years now. My '04 E was the same and I have always been perplexed as to why MB does this. At times I like to use the high beams manually and you need to move off the auto setting for this to work. Not being able to see the settings readily means you have to memorize the positions. I wish they were illuminated.
Old Dec 12, 2014 | 10:54 AM
Arrie's Avatar
Cheers!
My car is a 2010 model and it works like you describe. Light only on the actuator.
But the legend does get some light from the ambient lighting strip that is located very close above the switch.
Old Dec 14, 2014 | 02:56 PM
Cheers!
One other point reading the replies.When it comes to headlights t is either in one of two positions. Vertical wherein the high beams only work on the flasher and one notch to the right which makes the high beamd fully functional. Parking lights which are commonly used in Europe but I do use them occasionally are easy to figure out when you need them.
Old Aug 19, 2021 | 05:29 AM
Rodd's Avatar
E250 CDI (W212)
Thumbs up MB Light Switch Surround Illumination
I was wondering the same as you, having recently bought a 2011 E250 CDI (W212) Estate (wagon). Its light switch is illuminated, but not the surround, so the comments here make me feel better too. As you say, an odd design (oversight?) considering even the auto selector lights up!
