Sponsored by: CARiD
TPMS reset procedure isn't working
Old Jan 30, 2015 | 10:08 PM
Hifidude's Avatar
E350 ml350
Ok I had to have some repair work done on one of my tires and the guy said he reset the TMPS. I hopped in the car and have been driving around for weeks, doing the reset procedure also myself but only getting a message saying "tire pressure monitor active"....which I then reset again, get a confirmation saying its restarting......but then goes back to the "tire pressure monitor active" message.
I can drive till the cows come home but it never seems to collect a reading for the tires.
Looked all over this board and I can't figure it out. Help anyone?
Old Jan 31, 2015 | 08:49 AM
hyperion667's Avatar
2012 CLS63
does seem like an odd issue, they have always reset themselves for me when I had new tires or anything else done that required the adjusting or re-installing of the sensors
good luck OP
Old Jan 31, 2015 | 09:12 AM
imaphaetonguy's Avatar
GLC300
I don't know if this will help you any.
https://mbworld.org/forums/wheels-ti...e-message.html
Old Jan 31, 2015 | 11:15 AM
Hifidude's Avatar
E350 ml350
I probably should add the "repair work" involved putt my a new tpms sensor on one tire....
Old Jan 31, 2015 | 02:52 PM
2012 CLS63
even stranger........I've never had to buy another sensor.......this is my 4th Benz with sensors for tires too........I'd be skeptical
Old Jan 31, 2015 | 03:19 PM
RA72825's Avatar
How old is your car? I don't see it in your signature. I would assume the one new TPMS is causing the fault, or you have a gremlin in the system. The system is generally pretty bulletproof.
Old Jan 31, 2015 | 04:41 PM
Hifidude's Avatar
E350 ml350
It's a 2012 but the sensor needed to be replaced because it came off while inside the wheel.....and got beat to heck.
Old Jan 31, 2015 | 05:35 PM
Airmousam's Avatar
2010 E550 4M P2 Distronic, CLK550 Cab P2
Take it back to where you got the tire work done and ask them to fix it
Old Jan 31, 2015 | 05:46 PM
RA72825's Avatar
I think the system is searching relentlessly for that new sensor and it is not registering, so no go, thus fail to start.
Old Feb 2, 2015 | 11:50 AM
1guitar's Avatar
E300-4matic
You know that the TPS sensors work on different frequencies, did you mention that one of them was replaced, perhaps that is the wrench in the works. I believe the factory's TPS's work on frequency 433MhZ. Your problem is definitely the sensor that was replaced, it's messing up the other three.
Old Feb 2, 2015 | 09:03 PM
Hifidude's Avatar
E350 ml350
Ok so I took it back to the guys who put the tires on and they said the driver rear tpms was showing a fault even though they replace the driver passenger....and since that day it didn't work.
I don't know....I don't get this stuff but the guys fixed it. Many thanks to everyone on this board for their helpful comments.....I was going nuts
Old Feb 2, 2015 | 09:42 PM
RA72825's Avatar
Nice. Happy motoring!
