Sponsored by: CARiD
Slight jerk after stop
Old Nov 10, 2015 | 10:44 AM
The G Man's Avatar
2019 E300
Does anyone feel a slight jerk a second or so after coming to a complete stop? This happens intermittently and it almost feels like a car lightly tap me in rear, which is not the case of course. If I put the transmission in neutral, it does not jerk. At first I thought the transmission is downshifting to 1 gear, but the car is in the comfort mode and it should only go down to 2nd gear. Any ideas?
Old Nov 10, 2015 | 01:51 PM
jahquan3's Avatar
2010 E550 P2 w/AMG Sport Package + Pano, 2015 Nissan Pathfinder
I have yet to feel this happen. I also wonder what it could be.
Old Nov 10, 2015 | 03:08 PM
RA72825's Avatar
Check for codes. Valve body would be my guess.
Old Nov 10, 2015 | 03:18 PM
The G Man's Avatar
2019 E300
I will mention it the next time I bring it to the dealer, I also have the infamous ash tray door that doesnt spring back. Thanks for response.
Old Nov 11, 2015 | 02:48 PM
jonUF02's Avatar
2015 GL550 4matic
not feeling what you say, but new to this car, and I feel like if I sit at a light for a min, then just as I take my foot off the brake, there is a little jerk, like it's gone out of gear, into neutral, and has to go back into gear to take off. It seems more exaggerated in Sport mode. Maybe another description would be that the brakes are clamped really tight, and a tiny delay from taking my foot off the break to going forward??? Brake pads look new, and rotors seem fine. It's barely there, but just something that felt a tiny bit funny to me.
Old Nov 11, 2015 | 02:58 PM
RA72825's Avatar
The car has a 'HOLD" function on the brake. You aren't in that mode are you? It says hold. Next time you are at a light and stopped, press firmly again on the brake and you will see "Hold" pop up on your screen. The car will not move with your foot off of the brake pedal until you step on the gas again. There is a slight delay.
Old Nov 11, 2015 | 03:01 PM
jonUF02's Avatar
2015 GL550 4matic
Guess I need to read the manuals...
Old Nov 22, 2022 | 01:37 PM
revolutionml55's Avatar
Porsche993-ML55AMG-WRX STI-soon e55 211
Anyone figure this problem out I have it on both cars when I stop at a stop sign a second later it has a slight jerk.
gla250 and gle350
Old Nov 22, 2022 | 08:35 PM
Quint22's Avatar
Veteran: Navy
2014 Cummins, 2014 E250 Bluetec
Have same issue posted a while back and got no real answers. Mine does exactly same, about 2 to 3 sec after stopping.
i need to do trans fluid and filter but figure its probably the solenoids need cleaning but not sure
Old Nov 23, 2022 | 06:25 AM
Dane500's Avatar
2013 E550 Sedan, 2005 E500 4matic Wagon
Mine does it. Its appears to be gearing down. Whether from 3 to 2 or 2 to 1. (Eco vs sport)
You can make the car do it with the paddles. For me it all depends on how abruptly i come to a stop. Slow roll, it doesn't. A more aggressive stop and it will.
It's either that or the converter is locking up partially for better acceleration after a stop.....or the car is trying to open my wallet.
Old Oct 3, 2023 | 05:04 AM
Olivers_Rage's Avatar
CLK 55; C200 Kompressor
C200 here; yes my car has started doing this also, I did a oil change and now it doesnt happen as frequent or is as noticable as it was before some clean fresh oil, but i do notice it still happening intermittendly, my next guess is a change of sparkpugs maybe? There are no misfires and once the car moves it rides smoothly/normally, its just every now and then when coming to a complete stop, there a slight jerk kinda feels like a misfire.
any advice or help on what to look for would help alot.
Old Nov 20, 2023 | 09:00 AM
jakubk's Avatar
2016 E250
Has anyone successfully resolved this?
I also get a slight jerk after I come to a full stop in drive.
I also feel like when you release the break in drive, there is a slight delay before the car starts rolling forward, almost like something is sticking.
I'll be doing a transmission service soon to hopefully fix this, the car has just over 80K kms.
Old Nov 20, 2023 | 07:46 PM
rodrigra94's Avatar
Veteran: Air Force
2011 E350, 2020 C300 and 2005 C230
I had this issue on my W203. For me, it was the valve body going bad. I connected a code reader and discovered a couple of codes stored (P2203 and P220A). I purchased a new valve body from FCP Euro and replaced...issue resolved. Good luck.
Old Nov 20, 2023 | 08:26 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
hill assist feature
This is a genuine feature!
that's a hold function done by ESP on hills to keep car from rolling backward before pickup.
You shouldn't notice that at all on the flat, right?
