Sponsored by: CARiD
e350 Rain Sensor Wipers not working properly
Old May 6, 2016 | 08:03 PM
sghokie's Avatar
2010 e350
If I put my wipers on either of the intermittent settings they seem to work okay for about 10 seconds when it is raining then the wipers start going into ludicrous mode.
I really hate my wipers when it rains because I end up just pressing the single use button all the time. How can I get the rain sensor to work properly?
Old May 6, 2016 | 08:55 PM
The G Man's Avatar
2019 E300
Have your windshield been replace before? Did you try cleaning your windshield area where the sensor is located.
Old May 6, 2016 | 09:10 PM
sghokie's Avatar
2010 e350
Its the original windshield I think. Window is clean. This has been happening for over a year now.
Old May 6, 2016 | 09:44 PM
thefisch's Avatar
Top Answer: 1
2011 E550 P2 4M Sedan
Happens to me from time to time. Usually turning off and then back on gets it back to non-ludicrous speed.
Old May 6, 2016 | 10:24 PM
sghokie's Avatar
2010 e350
If I turn it off and back on it works again for 10 seconds again then goes to ludicrous speed.
Old May 6, 2016 | 10:41 PM
jumpman726's Avatar
2024 E350
Sounds like there might be a problem with the camera/sensor and it thinks that it's pouring heavy rain which is causing the wipers to go in "ludicrous speed."
Old May 7, 2016 | 12:04 AM
user 58362638's Avatar
I just couldn't resist!
Old May 7, 2016 | 09:07 AM
sghokie's Avatar
2010 e350
LOL.
Is the camera fixable?
Or do I just have to wait until my Tesla Model 3 is ready?
Old May 7, 2016 | 09:33 AM
RA72825's Avatar
Yep, turn off then on. Every MB I have owned has had this issue. I have concluded that the system has always been problematic and never addressed properly by MB over the years.
Old May 7, 2016 | 09:48 AM
sghokie's Avatar
2010 e350
I had an 03 c320 and the rain sensor worked okay.
Old May 7, 2016 | 10:16 AM
sghokie's Avatar
2010 e350
I just took off the sensor and cleaned the 4 lenses and the windshield inside and tested.
Same result.
Old May 7, 2016 | 05:49 PM
konigstiger's Avatar
'71 Pinto
Have someone pull /clear fault codes with MB SDS. Need VIN to supply rain/light sensor part # if replacement needed, removal: http://workshop-manuals.com/mercedes...ons/page_1845/
Old May 7, 2016 | 07:55 PM
sghokie's Avatar
2010 e350
Its pretty easy to remove. I just took it off today.
I suspect it is bad.
Old May 8, 2016 | 09:42 AM
aquinob's Avatar
2010 E350, Sold 1998 C230
I have the same issue. Will try the shut on and off and see if it makes a difference. But I see this as just another bit of MB over engineering, a much simpler system that would let you set a time delay for each wipe would be bulletproof. Coming from a '98 C that used vacuum for everything and of course didn't work all that well after years, its nothing new either.
Old May 8, 2016 | 01:46 PM
'71 Pinto
Another member posted this reset, consider this before replacement.
Attached Thumbnails e350 Rain Sensor Wipers not working properly-capture.jpg
Old May 8, 2016 | 02:57 PM
sghokie's Avatar
2010 e350
Thanks, I will try that.
Old May 23, 2016 | 12:37 PM
sghokie's Avatar
2010 e350
I tried the reset procedure during a rain event last week, and ironically the wipers worked fine all the way home. Unfortunately this morning they decided to not work again.
So I guess it needs to have a new rain sensor.
