Sponsored by: CARiD
Comand Screen Haze - can't see screen when in direct sunlight
Old Jun 22, 2016 | 03:03 PM
sleeperZ96BT's Avatar
2013 E550, 2014 GLK 350
Hi All,
My 2013 E550 has this 'haze' over about 2/3 the screen where the screen looks fine in normal/low light but when the sun is beaming on it, you can't actually see what is on the screen in the area impacted due to the haze.
The dealer is telling me that they won't cover it under warranty (it's CPO) and that this is normal wear and tear. I'm trying to figure out how this would happen because it isn't a touch screen as far as I know so why would someone be touching the screen in such a manner to make this possible.
Do these things delaminate over time or something? My wife's 2014 GLK has no such issue.
Any help would be great!
Brian
Old Jun 22, 2016 | 03:28 PM
thefisch's Avatar
Top Answer: 1
2011 E550 P2 4M Sedan
could it be some kind of residue from a past cleaning? Sometimes after taking it to a wash place, I've noticed more glare in certain spots that I've had to wipe off to remove.
Old Jun 22, 2016 | 04:17 PM
The G Man's Avatar
2019 E300
I am guessing the last owner try to clean the screen with the wrong cleaner and remove the anti glare coating.
Old Jun 22, 2016 | 04:24 PM
RA72825's Avatar
Yeah, something is amiss there. The M-B COMMAND screen is one of the best in the business in terms of being clearly view-able under any light conditions.
Old Jun 22, 2016 | 04:57 PM
beejAMG's Avatar
W204 C63 AMG, W212 E250 CGI, C207 E250 CGI
+1 on all 3 comments.
a photo of the problem might help.
Old Jun 22, 2016 | 08:47 PM
Peachy's Avatar
2010 E550
Have you tried changing the brightness of the screen? Maybe it's just too low? :B
Old Jun 23, 2016 | 10:13 AM
I did some further homework, and I think this is it. Wrong cleaner, either by the prior owner or the dealer. Pictures I saw looked like what I saw in these threads where they used a bad cleaner.
There are some solutions, I guess, from cheap (DIY stuff removing screen and then overlaying something) to having the dealer replace it (no idea how much it costs, but can't be cheap).
Old Jun 23, 2016 | 10:35 AM
thefisch's Avatar
Top Answer: 1
Sorry about that. Can you post some pics or links so the rest of us can watch out for it?
Old Jun 23, 2016 | 10:44 AM
RA72825's Avatar
There is no easy fix for this that I am aware of. Sorry.
Old Jun 23, 2016 | 11:07 AM
Here's where I got the bad news and also the pictures in here show what my screen looks like:
https://mbworld.org/forums/w211-amg/...nd-screen.html
Hope it helps!
Brian
Old Jun 23, 2016 | 11:17 AM
thefisch's Avatar
Top Answer: 1
Seems like the cheap fix worked for those folks. Are you going to try it?
Old Jun 23, 2016 | 11:34 AM
Maybe, it's not quite annoying enough for me to go gung-ho and fix it now. In the month or so I have had the E550 it only has happened twice where I could not see it.
Old Jun 23, 2016 | 01:30 PM
The G Man's Avatar
2019 E300
I have seen people remove the anti glare coating all together and place a anti glare film on the screen with good result.
