Sponsored by: CARiD
How long does fob battery last?
Old Aug 17, 2016 | 09:33 AM
The G Man's Avatar
2019 E300
My fob battery is only 9 months old and I got a replace fob battery message when I try to start the car yesterday. Almost all my other car's fob battery will last more than 1 year, some as long as 2 years. How often do you guys replace your fob battery?
Old Aug 17, 2016 | 09:48 AM
JSch's Avatar
2019 Mercedes-Benz GLS
Mine also lasts about 9 months. Wife's Nissan remote's battery has never been replaced - 6 years old and the range is still the same.
I keep spare batteries in the house and in the car. Since I only use one key fob, I should probably check the other one's battery..
Edit: I have Keyless Go
Old Aug 17, 2016 | 09:55 AM
Ferris_E550's Avatar
MB E550 2010
When I got my CPO three years ago the dealer replaced the fob battery, it is still working just fine.
Old Aug 17, 2016 | 10:05 AM
CarolinaBluetec's Avatar
2008 E320 Bluetec (until 11/14), 2001 SLK 320, 2004 Volvo V70, 1972 MGB, 2013 E350
20 months since last battery change.
Old Aug 17, 2016 | 10:37 AM
The G Man's Avatar
2019 E300
Do you guys have keyless go?
Old Aug 17, 2016 | 11:47 AM
RA72825's Avatar
I get about 1 year and I have Keyless Go
Old Aug 17, 2016 | 12:26 PM
sleeperZ96BT's Avatar
2013 E550, 2014 GLK 350
6-12 months with keyless go has been my norm. I think where we park and where the keys are causes it (it's somewhat close to the house).
Old Aug 17, 2016 | 04:17 PM
thenew3's Avatar
2020 X7 xDrive40i, 2016 X3 sDrive28i
With keyless go E350, 3-6 months on average with the CR2025, with a slightly thicker CR2032 it lasts about a year.
Without keyless go C300, battery at 5+ years and still working fine
Old Aug 17, 2016 | 05:16 PM
dbldpr's Avatar
Veteran: Navy
The first time I had oil change the dealer replaced the battery on remotes. They lasted about 2 weeks Went back and told them to use new batteries this time. Knock on wood I now go in once a year for oil change and I have them replace the batteries. No problems since I told them to use new batteries.
Old Aug 17, 2016 | 05:23 PM
SEC1939's Avatar
2015 E 250, 1999 BMW M Roadster, 1939 International Harvester, 2023 GLC
I read somewhere there is a TSB on the "replace key battery" warning. A software issue.
My 05 W211 never had battery replaced. They should last a few years I'd think.
Old Aug 17, 2016 | 05:34 PM
dbldpr's Avatar
Veteran: Navy
My dealer says it should be replaced once a year, I can live with that. The wifes cadillac has the original battery in remote and it is 16 years old. But then again that is an american car. Just the engines and transmission go out and you have to replace them.
Old Aug 17, 2016 | 10:43 PM
Ejbrock's Avatar
2012 C63 P31 Coupe. 2007 SL55. 1992 911 C2 Coupe
EJbrock
I have keyless go on two cars. The batteries last about one year.
Old Aug 18, 2016 | 05:00 AM
MB E550 2010
Yes I have Keyless Go
Old Aug 18, 2016 | 08:55 AM
Yes, I have Keyless go.
Old Aug 18, 2016 | 09:45 AM
The G Man's Avatar
2019 E300
My old BMW had keyless start as well and I park and leave my keys at the same spot in my house, the BMW fob battery lasted over 2 years before it needed replacement.
Old Aug 18, 2016 | 09:59 AM
YYZ-E55's Avatar
MY17 E43 Matte Selenite/Macchiato Beige, MY16 GLE350d Tenorite/Crystal Grey, MY17 B250
Around one year if you have KEYLESS-GO.
Old Aug 18, 2016 | 10:18 AM
The G Man's Avatar
2019 E300
Have you tried using a CR2032 on the fob?
Old Aug 18, 2016 | 07:16 PM
El Cid's Avatar
Veteran: Army
2010 E350 Luxury Sedan, Engine 272 (V6)
Replaced it in fob I ordinarily use at four years because cheap to do. Ironically, the fob I almost never use has 7 year old battery that still works fine. Do not have keyless go.
My Nissan Rogue SUV has "keyless go" and battery only lasted 18 months.
Old Aug 18, 2016 | 07:23 PM
@dman's Avatar
2012 E550 (W212)
I'm not sure how long mine lasted, since I picked up a 2012 CPO nearly a year ago. One fob runs strong, the other's battery died on the morning commute a few months ago. There wasn't much notice, and I now keep a spare battery in the center console just in case.
-Adam
Old Aug 18, 2016 | 09:20 PM
Ejbrock's Avatar
EJbrock
+1 on keeping extra fob batteries in the car.
Old Aug 18, 2016 | 09:24 PM
thefisch's Avatar
Top Answer: 1
2011 E550 P2 4M Sedan
Had my W212 for 2 years and already done 3 replacements (although one was by dealer when there was no warning).
I had a Toyota with keyless (smart key) for 8 years and never needed to replace battery.
MB is just better at everything.
Old Aug 19, 2016 | 12:24 AM
ljoeurban's Avatar
E350-2014 Sport ,Honda 2001 Accord, FireBird-1992-Formula
I was getting 3-6 months on key fob batteries with KEYLESS-GO. Dealer said keep key fobs away from each other. If kept close to each other they talk to each other and run down.
(Forgot when this was.)
Old Aug 19, 2016 | 01:58 AM
Abrown3mtg's Avatar
2010 E550 4Matic Sport P2
Replace them more often.... I learned the hard way when I left my key in the car and it locked but would not open.... had to call roadside. Not a fond memory. Resulted in a "how to break into my own car" thread here last summer....
Old Aug 19, 2016 | 09:42 AM
thenew3's Avatar
Yes, I've used several different CR2032's and they more than double the life of the CR2025.
They are a little snug and do require some work to take out, but other than that they work fine.
Old Aug 19, 2016 | 09:47 AM
The G Man's Avatar
2019 E300
Thanks, good to know, I will order some 2032. On paper, the CR2032 has 47% more capacity than the CR2025, 163 mAh vs 240 mAh.
