Sponsored by: CARiD
2014 E350 Automatic trunk won't fully close.
Old Oct 4, 2016 | 02:16 PM
Hippocrateez's Avatar
E350
Unhappy 2014 E350 Automatic trunk won't fully close.
Hey guys, searched the existing forums but couldn't find anything so making a new thread. 'If the question is answered somewhere else please do direct me. I've got a 2014 e350 with the automatic trunk open/close. The only problem in its operation is when I hit the button on the trunk to auto close, or even use the close button in the door up front, the trunk comes all the way down but right at the last point when it clicks shut it just goes right back up. If I push it down manually at that point it locks. I checked along the trunk and trunk lid lines for possible obstructions but found nothing. If anyone knows what's going on please help. Thanks!
Old Oct 4, 2016 | 02:57 PM
RA72825's Avatar
Sounds like the latch needs to be adjusted properly.
Old Oct 4, 2016 | 03:30 PM
konigstiger's Avatar
'71 Pinto
Should be covered by factory warranty. Pull fault codes using STAR (MB diagnostic system) "may" simply need to normalize control unit.
Old Oct 4, 2016 | 07:35 PM
beejAMG's Avatar
W204 C63 AMG, W212 E250 CGI, C207 E250 CGI
just to be clear, you hold the button down all the way til it tries to lock yeah?
Old Oct 4, 2016 | 09:38 PM
E350
Yes, with the door button in front I hold down all the way continuously but it comes back up slowly as if it were being opened right at the last second when it's closing. With the trunks own button to auto close I just press as it meant to be
Old Oct 4, 2016 | 09:39 PM
beejAMG's Avatar
have you tried opening/closing using the button on the key fob?
Old Oct 4, 2016 | 09:45 PM
E350
The fob will open it just fine but I think it can't close the trunk regardless of the issue. I believe the sedan trunk can only be opened with fob.
Old Oct 4, 2016 | 10:17 PM
beejAMG's Avatar
oh ok i didnt know that. ill check mine later. nonetheless, check post # 3 Konigstiger.
Old Oct 4, 2016 | 11:57 PM
beejAMG's Avatar
Youre right, it will open with the fob but wont close. Did you try closing it with the button in the boot?
Old Oct 5, 2016 | 09:16 AM
blegthbloo's Avatar
2013 E550 4Matic
You have to hold the door button until a few seconds AFTER it fully closes, so the latch engages. If you're letting go as soon as the lid shuts, it doesn't have time to latch. It's very slow.
Old Oct 5, 2016 | 07:35 PM
E350
Since it's a bidirectional button up front in car, I hold it down in the close direction, even continuing to hold it down while it's popping back up
Old Oct 5, 2016 | 07:36 PM
E350
Yes I mentioned using the button in the trunk, unfortunately did not work, that's the usual way I'd close it once I'm done loading the car. Even the kick method to close it results the same way, all the way down, last second back up
Old Oct 5, 2016 | 07:44 PM
beejAMG's Avatar
oops, sorry i missed that from your original post.
the last thing to do now is have the latch re-adjusted or "normalize" the system like Key8 and konigstiger suggested. goodluck mate and hope its an easy fix.
Old Jan 2, 2020 | 06:07 PM
craiger13's Avatar
2018 E400 Coupe
Trunk open out of nowhere
I Just had an weird issue happen to me.....I was driving home and my trunk opened. I could not close it until I put it in park. I was thinking that I might have hit the fob while it was in my pocket but after parking it in my garage I hit the trunk release on the FOB and it would not open until I hit it 5 times.
Old Jan 2, 2020 | 10:12 PM
Ghettoeg6's Avatar
E350
had this happen to me last year. i have part number and konigstiger provided the instructions on how to change out the power soft closing motor. it took me like 5 mins to swap out.
https://mbworld.org/forums/e-class-w...ml#post7605270
Old Aug 23, 2020 | 06:20 PM
Shaeer Ahmed's Avatar
E350
Mercedes e350 w212 boot lid keeps bounces back open when closing with button inside
Hi there, i have the exact same issue with my boot lid closure on my w212 e350, just wondering if you managed to get to the bottom of resolving the issue with yours? Would really appreciate your help or advise thank you
Old Aug 23, 2020 | 09:27 PM
Ghettoeg6's Avatar
E350
See my post and link in post #15
Old Aug 24, 2020 | 01:15 PM
nota_amg's Avatar
2013 SL550 BiTurbo
Trying to wrap my head around this and all I can come up with is the latch is not moving to the upper position to accept the trunk latch? is the entire assembly motorized, for the "auto-close" or "soft-close" feature? Right? Because the trunk lid comes down and engages the latch lock before the lid is closed, THEN the latch assembly moves "down" into the body to fully close the lid??? I know old GMs used to work like this in the 80's...surely it's more complicated than that, right???
crap...no I gotta play with my trunk latch before I go home tonight! lol
