Sponsored by: CARiD
W212 possibility K40 problem
Old Dec 30, 2016 | 01:28 AM
Zamzul's Avatar
E250 CDI
Question W212 possibility K40 problem
Hi, I have a problem with my W212 e250 where I cannot start the car after replacing my alternator. The engine not even crank and the radiator fan keep on intermitten running even my keys in off position.
In the mb forum people did mention K40 relay and I could not find similar to my car.
Need help to some one who have the same experience with same model w212
Old Dec 30, 2016 | 10:12 AM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W212 forum...
Old Dec 30, 2016 | 08:46 PM
Zamzul's Avatar
E250 CDI
Originally Posted by Plutoe
You have to first start testing things----first--is the battery fully charged. Second can you start the car by going directly to the starter from the battery? Third have you checked all the wiring you removed during the alternator installation? Have you checked the starter relay?----now post your VIN!!
Hi thanks for the respond.
1- yes the battery had been fully charge.
2' can we do direct start (starter motor directly connected to battery- jump start)?
3- the alternator wiring is connected fine as it using unik socket to each individual connection.
4- the starter fuse fine which in E250 fuse box 6,7,19&27. But could not figure which is the starter relay.. can i have the picture or diagram?
For further information I had open the fuse box and found no burning pannel.
Once i connect the battery it makes a clicking sound on the relay (may be overload protection relay).
My VIN # WDD212047-2A-125066
Regards
Old Jan 2, 2017 | 06:14 AM
Zamzul's Avatar
E250 CDI
W212 have power but not cranking
Hi happy new year to all.
I have a problem with my w212 which have full charge battery (12 to 13v) howevet no crank when i turn the keys to start mode.
There is a clicking sound one of the realy inside the SAM and few second the radiator fan start to run.. even when i switch of my key..
Need help to someone have this experience.
Old Jan 2, 2017 | 01:22 PM
thefisch's Avatar
Top Answer: 1
2011 E550 P2 4M Sedan
Does the car start with a jump start from another car or donor battery?
First thing to suspect is normally the battery. Voltage on these agm batteries can be misleading. The battery shows a high enough voltage but the amps aren't there. A load test of the battery when it is out of the car is the best way to tell.
Old Jan 3, 2017 | 03:42 AM
Zamzul's Avatar
E250 CDI
Hi thanks for the information and yes i had done the jump start and still no crank from the starter motor.
The clicking still hapen with the fan cooler switch on even without any key on.
Is it.something to do with the clicking sound the relay inside the SAM?
Regards
Old Jan 22, 2017 | 10:54 PM
Zamzul's Avatar
E250 CDI
Thumbs up Problem resolve
[QUOTE=Zamzul;7009236]Hi, I have a problem with my W212 e250 where I cannot start the car after replacing my alternator. The engine not even crank and the radiator fan keep on intermitten running even my keys in off position.
Need help to some one who have the same experience with same model w212[/QUOTE
Hi I have resolve the problem of this issue.
Thanks for the reply anyway
