Sponsored by: CARiD
Seat button coverd by warranty?
Old Jan 30, 2017 | 11:44 PM
Kevin Park's Avatar
2014 E350 4matic,
Hi, I just found my driver seat adjust top button is missing.. I could not find it in my car. I was wondering will it be cover with warranty? there is some buttons i can buy on ebay but if it cover, I would like to get original part.
Thank you!
Old Jan 31, 2017 | 01:14 AM
PatrixUSA's Avatar
2014 E350 W212
If you're within the mileage limit (I would assume so on a 14, but we know what assuming does) I would think this would be covered. Only way to know for sure is to have your dealer take a look and assess. Good luck.
Old Jan 31, 2017 | 07:53 AM
SEC1939's Avatar
2015 E 250, 1999 BMW M Roadster, 1939 International Harvester, 2023 GLC
these break off easy. not a robust design . My W211 broke. I managed to super glue it on
Old Sep 11, 2017 | 05:48 PM
Mbracer26's Avatar
Past 03 SL500,03 C240, 07 E350, 07 ML350, 10 ML350,11&14 E350 X2 2017 E300, 2017 C350e & 2000 S500
Same button has broken on mine, and cant find it either. What was your solution, did the dealer fix it for you?
Old Sep 11, 2017 | 09:32 PM
tresean1's Avatar
Veteran: Marine Corps
W212 E-class, W211 E-class, F10 5-Series
My best friend got his covered under warranty, but the trick is to finagle the gripe. You have to present it not as a trim piece, which is not covered under warranty, but as a functionality issue. Meaning: without that button you cannot adjust your seat properly. Good luck.
Old Sep 12, 2017 | 02:28 PM
Mbracer26's Avatar
Thank you for the reply, I wish you had the service papers to see how he worded his request. Will give it a try.
Old Sep 12, 2017 | 10:25 PM
looney100's Avatar
None
Had the exact same switch break on our E250. dealer would not cover under warranty.
Old Sep 13, 2017 | 09:43 AM
tresean1's Avatar
Pretty much the gripe was "seat cannot be adjusted due to inoperable control, use of head-protection system incorporated into headrest will not be optimal" (basically, the task is to get them to see it as a deficiency in workmanship to not be able to adjust the headrest, and as a potential safety issue in the event of a rear collision). Do not argue it simply as "trim that fell off"...ignoring the latter, they replaced it under the former conditions. IIRC, they had to remove the door trim and replace the entire underlying unit (seat adjustment, memory, etc), as the headrest switch is not sold separately. They know that, and it's costly, that's probably why they are avoiding it. Good luck!
Old Sep 14, 2017 | 02:57 AM
Mbracer26's Avatar
Why didnt I think of that earlier, that is so smart, why didn't I ask for help from the forum earlier! Thank you for your help, I will take in the car and hopefully it will work.
Old Sep 24, 2017 | 10:37 AM
tresean1's Avatar
how did you fare?
