Retrofit/mount larger screen for NTG4.5/7
2014 E350
Sooo...here we are again.
I have a 2014 E350 with COMAND ONLINE. My biggest and probably only complaint about my car is the size and location of my 7 inch screen.
I've done a ton of research online and in the forums about retrofits and larger screens. It seems as though you need NTG5+ with the iPAD style screen to do a screen upgrade.
My question is this...Can we install an aftermarket screen with preferably an Android OS built in that has capabilities like GPS, WIFI, etc? My logic is this, the main screen is hooked up with a FAKRA cable. Can't we unhook the FAKRA cable and convert the signal to either HDMI/RCA to input into the aftermarket screen that has input capabilities?
My main goal is the following:
1. larger screen 8 inch+
2. be able to switch between the android OS and the stock COMAND system using the aftermarket screen inputs.
3. lose ZERO functionality.
4. mount the larger screen in front of the OEM screen in the available space.
I have seen this done...to an extent on YOUTUBE. to see an example of what i'm trying to you can go here
I have also heard that CAN-BUS hacking might be useful in this scenario also
Any suggestions, opinions, etc are extremely welcome.
2014 E350
From what I have been reading it seems you can just disconnect the FAKRA cable from the back of the stock 7 inch COMAND screen and hook it up to another screen without issue or at the very least use a CAN-BUS cable to trick the car I think. Can anyone with extensive experience verify any of this???
W212 E-class, W211 E-class, F10 5-Series
How would you do that. A simple "mount" would seem awkward and conspicuous. Wouldn't this require extensive reworking of the dash area?
2014 E350
Sounds interesting, but what about resolution, alignments, etc. The delta would be pretty noticeable when going from a 6" to 10" screen.
2014 E350
I have managed to find the new screen with android OS and any necessary cables that might work as part of the process.
With that said...does anyone know the COMAND system and electronics really well that could almost walk me through the process if even possible?
2014 E550, 2015 E63S, 2017 G63 - RIP
Are you sure you want to do this?
IMHO iPad mounted inside the cabin or a larger iphone will look and function better.
This mod will completely ruin flowing lines of the dash...but...it's your car
2014 E350
Without question yes! Screw the flowing lines, the car needs something to make it pop more on the inside anyway since it's been using the same interior scheme for years.
2014 E350
I have contacted NAVIKS and CAR SOLUTIONS and they do not think they have anything in the way of an "interface" that would allow the hookup of a after market screen in place of the OEM screen when it comes to the cables and such.
I know they make FAKRA cables that can either be striped or converted to RCA/HDMI to hook up another screen which is my intention. However, I think the real problem arises with the car sending the data to the after market screen as opposed to the OEM. This doesn't really make sense to me because a screen is just a screen and it shouldn't matter what the data is outputing to as long as the screen can play it. Perhaps maybe its a CANBUS issue but if thats the case then they make cables for that too to trick the system...I honestly dont know my grasp of this EXTREMELY INTRICATE (yet unnecessary) electrical system.
Hopefully some of you have some insight or info
cadetdrivr (10-23-2017)
I think the oem 8 inch screen without bezels should fit from the newer command units. That should give you a larger screen and keep full functionality. Then have a new bezel fabricated to make the new screen blend in as best as you can in the original mounting position.
2014 E350
Although, I would like the "new" screen to have and ANDROID OS built in with multiple inputs. That way you have all the OEM stuff on one source and then also be able to switch over to the android os for other apps like google maps and such. I guess we'll see what happens very soon.
I just like nice things...
