Sponsored by: CARiD
W212 Spring Pad Part #s: No Luck and Searched for Hours
Old Nov 2, 2017 | 08:32 PM
Ransomed12's Avatar
2013 SL550
Team:
I've seen countless threads with no spring pad #s for W212s. I've got an e350 sport and looking to have the pads swapped out. Help me and everyone else searching.
Thanks,
Daniel
Old Nov 3, 2017 | 06:34 PM
Ransomed12's Avatar
2013 SL550
Thanked!
Vin #: WDDHF5GB7AA077519
Model: E350 Sport no-4 matic
Old Nov 3, 2017 | 07:08 PM
konigstiger's Avatar
'71 Pinto
See attachments.
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old Nov 22, 2017 | 05:36 AM
W212fromW211's Avatar
E550 4Matic
I ordered some for the 210 the part number is the same. They said they wouldn't fit but for $20 at the dealer if they didn't fit no sweat. Went with the 5mm pad on h&r .
Old Feb 12, 2018 | 11:21 AM
RedRacer's Avatar
W210
Do W212 front spring pads (part #40 on spring2.pdf above) come in different thicknesses? I am searching for the thinnest one possible.
Old Jan 30, 2020 | 02:39 PM
EuroDriverSD's Avatar
2016 E350 Sport; Mom Wrecked the 2008 E350; sold the 2002 C320
Reviving an old thread for the sake of avoiding redundancy, since I just went through this investigative exercise.
Front Spring Pads (aka coil spring shim or coil spring insulator):
There are no variants for pad thickness. Only 2 part numbers are available:
A 212 322 01 84 which is superseded by part number A 212 322 02 84
I have been able to find these under both part numbers online. However I was unable to determine the thickness of either nor the difference between the two. They are easier to find without the "A" in the part number.
Rear Spring Pads (aka Rubber Pad):
There are 4 thickness variants available:
210-325-01-84 = 5mm
210-325-02-84 = 9mm
210-325-03-84 = 13mm
210-325-04-84 = 17mm
Here is a picture of 210-325-01-84 (5mm). It is identified by the 1 nub on the edge of the inside lip.
1 nub = 5mm
2 nubs = 9mm
3 nubs = 13mm
4 nubs = 17mm
My 2016 came equipped with the 210-325-02-84 (9mm) pads. Here's a pic for comparison (note the 1 nub vs 2 nubs on the pad lips)
A little piece of advice - if you're going to change the spring pads, do yourself a favor and also buy part #A 212 326 03 77 (# 100 on the diagram "springs4" in post #4 above). It's a royal bear to get the rubber pad out of there. You'll need 2 of them.
Old Jan 31, 2020 | 10:49 PM
AlvinDj's Avatar
W212 FL E250
Any tutorials or WIS to replace these spring perch pads?
For W212 FaceLift E250 Sedan 2015
Old Jan 31, 2020 | 11:35 PM
Due to my bad back, I can no longer take on these kinds of projects so I had a shop do it.
Here's a tutorial that was posted some time ago - the pics are no longer available but it'll give you a good idea
Spring Replacement DIY Tutorial
Old Jan 31, 2020 | 11:43 PM
AlvinDj's Avatar
W212 FL E250
The springs have to be completely removed in order to replace the rubber pads?
Old Feb 1, 2020 | 12:07 AM
Yes. The pads are above the top of the springs, inside a plastic housing. The springs need to be pulled out entirely
Old Feb 7, 2020 | 08:06 AM
'71 Pinto
As requested.
File Type: pdf
Old Jun 12, 2020 | 04:31 AM
raj.134's Avatar
E250
As requested.
Hi, would you be able to check by VIN number to find out which spring pads I have, please?
VIN: WDD2120032A950441
Old Jun 12, 2020 | 10:00 AM
'71 Pinto
See attachments.
File Type: pdf
File Type: pdf
File Type: pdf
Old Jun 12, 2020 | 10:51 AM
raj.134's Avatar
E250
See attachments.
Thank you so so much!! much appreciated!
would you know what lower spring seal is? is called out to replace it when changing springs?
also, as mine has the 5mm pad, is there any point to get a new one when lowering the car. I can use the existing one right?
thanks/
Old Jun 12, 2020 | 01:42 PM
'71 Pinto
Shim front (20 in diagram), rear (120).
Old Dec 30, 2020 | 08:39 PM
Alimalik1's Avatar
E350cdi w212
As requested.
any chance you could check my vin to see which pads i have? new on here would be grateful thanks wdd2120232a631595
Old Dec 31, 2020 | 08:26 AM
'71 Pinto
See attachments.
File Type: pdf
File Type: pdf
File Type: pdf
Old Dec 31, 2020 | 09:14 AM
Alimalik1's Avatar
E350cdi w212
See attachments.
cheers thanks alot for that i was wondering why it was sitting so high at the back with h&r springs i have the 13mm pad will be swapping out for the 5mm get it level
Old Nov 18, 2024 | 03:04 PM
4wheeling's Avatar
1994 Mercedes Benz E420
I know I am reviving an old thread and risking catching some heat, can I get the front and rear spring, shock/strut, and related parts info for vin wddhf8jb1da720624?
