Sponsored by: CARiD
Interior HVAC and Command Control Ilumination
Old Jan 30, 2018 | 09:11 AM
801's Avatar
801
2012 E350 4matic Sport
Title says it all ... anyone know how to turn on the illumination of the switches of HVAC controls and Command buttons/controls?
Sure, they'll come on automatically based on some calibration-configuration based on something ... but anyway to just turn them on?
Driving into work this morning, dark, gray, flurries ... but just enough light outside (I guess) to keep my interior dark. Seriously?
For the record, switching the Command Display Mode to "Night" doesn't do it.
Old Jan 30, 2018 | 10:41 AM
RA72825's Avatar
If you go hard on the headlights(not auto mode) with the headlight switch, the dash and other interior lighting should illuminate, no?
Old Jan 30, 2018 | 10:43 AM
801's Avatar
801
That is a negative. Auto or On setting for headlights has no impact on interior switch illumination during daylight / dusk conditions.
Thanks, though.
Old Jan 30, 2018 | 11:27 AM
rediesel's Avatar
2006 E320 CDI 2014 C63 507 Coupe 2012 E550 4M 2016 E63s Wagon
Have you tried turning the small knob in the instrument cluster? I think it's under the gas gauge/clock.
Old Feb 1, 2018 | 09:26 AM
801's Avatar
801
That small knob under the gas/clock is simply the gauge cluster dimmer switch. It will not turn the HVAC and Command buttons illumination on or off.
I think I'm beginning to realize ... that Mercedes engineered my 2012 E350 ... without the ability to simply turn on interior controls illumination ... or off for that matter as well.
I'm thinking that's pretty f'in stupid.
Old Feb 3, 2018 | 10:29 AM
Johnny Rad's Avatar
W212 E550 4M P2
I’ve come to same conclusion. There’s a short window of time where my headlights automatically turn on, but the center stack illumination doesn’t come on for a bit. I’ve looked and looked for a button or switch, but no love.
Old Feb 23, 2018 | 10:34 AM
801's Avatar
801
So ... now that we've determined that there is no way to manually control the illumination of the Command and Climate control 'buttons' .... let's ask the next question.
Where is the "light sensor" that controls said illumination?
I thought it might be that little dome shaped bubble in the middle top of the dash close to the inside of the windshield ... but that's not it. I blacked that out (covered it up) with no result.
Any one? I do all of my commuting at twilight time (morning and evening) and it's just light enough for this mystery sensor to turn-off Command/Climate illumination .... but too dark for me to see the controls.
Yeah, I know, I've got them memorized at this point ... but I like having them lit up, you know? Sheesh. Interior lighting, ambience is a big deal, you know? And with the sea of black plastic in these pre-face lift W212's ... a little illumination on the
interior controls makes a big difference.
Old Feb 23, 2018 | 01:30 PM
konigstiger's Avatar
'71 Pinto
Ran/light sensor b38/2.
File Type: pdf
Old Feb 24, 2018 | 09:20 PM
Arrie's Avatar
What happens if you put the ambient light intensity to the max setting?
Old Feb 25, 2018 | 07:55 PM
thefisch's Avatar
Top Answer: 1
2011 E550 P2 4M Sedan
I just tried adjusting the small knob and it does adjust the brightness of the climate and comand buttons in my car. It is not an on/off in my case - it goes from low to high. The auto headlights were on.
