Sponsored by: CARiD
What are these two parts called? I'm rebuilding a salvage car and I can't find these
Old Mar 20, 2018 | 09:04 PM
Andrewjanks101's Avatar
2015 E 350
Old Mar 20, 2018 | 09:17 PM
ItalianJoe1's Avatar
2003 CL 600
It's all considered part of the upper radiator support. It's 3 pieces right? If you have a VIN, i'll try to look in EPC and find part #s for you to help with the search.
Old Mar 20, 2018 | 09:20 PM
2015 E 350
No I don't have the VIN number I just got the car today and these three pieces are missing and I can't find them on any website because I have no idea what they were called. Thank you for your quick response.
Old Mar 20, 2018 | 09:21 PM
2015 E 350
Old Mar 20, 2018 | 09:23 PM
2003 CL 600
Coupe or sedan? I'll look it up anyway.
Old Mar 20, 2018 | 09:43 PM
2003 CL 600
Check this out.
Part 10 is the center, 20 and 30 are the sides. It shows different part #'s depending on what options the car has and some have been superseeded. But they are called headlight frames, and the central "front stiffening" or brace.
File Type: pdf
Old Mar 20, 2018 | 10:15 PM
2015 E 350
It's a sedan. Thank you for the info. And just out of curiosity do you know where I could find specific screws and bolts for bumpers and fenders and stuff like that?
Old Mar 20, 2018 | 10:22 PM
2003 CL 600
MB sells all of that. They often aren't that expensive.
A 2015 is too new, but if I was putting one together and didn't want to spend on new ones, I'd visit a local u-pull-it type place and try to grab as many bolts as I could that were similar. Any older benz will have basically the same hardware, although not everything will be the same.
Old Mar 20, 2018 | 10:24 PM
2015 E 350
Thanks. I'll check it out. This is going to be a hard rebuild because I honestly don't know what screw goes where ��
Old Mar 20, 2018 | 10:30 PM
2003 CL 600
If you have access to EPC, the pictures show the screw locations and dimensions, so you will know what length of bolts go where, to a point. It's not perfect though, it will not be an exact picture of your car and can sometimes show only one of a bolt with a larger quantity. It can be somewhat of a guide though.
Old Mar 20, 2018 | 10:44 PM
2015 E 350
Okay I'll try but I don't have access
Old Mar 20, 2018 | 10:54 PM
Red-Town's Avatar
2016 MBZ E350
If you post VIN i can get you part numbers.
Old Mar 20, 2018 | 11:12 PM
2015 E 350
I unfortunately don't. Not for the parts at least.
Old Mar 21, 2018 | 12:05 AM
Red-Town's Avatar
2016 MBZ E350
year and model at least.
Old Mar 21, 2018 | 12:44 AM
2015 E 350
2015 Mercedes E350
Old Mar 21, 2018 | 12:45 AM
cetialpha5's Avatar
If you're going to be spending that much time looking for parts, try getting your own EPC which is what MB calls their parts look up system. You can get a knock off DVD on eBay for around $10, those also come with WIS which is the workshop information system. For official MB access, EPC is $75 a year and their Startek/WIS is like $60 a day for access.
Old Mar 21, 2018 | 12:47 AM
2015 E 350
Ok. I will check it out thanks
Old Mar 21, 2018 | 12:56 AM
Red-Town's Avatar
2016 MBZ E350
Frt Body Upper Tie Bar
212 620 11 00
R Frt Body Headlamp Mounting Panel
212 620 47 00
L Frt Body Headlamp Mounting Panel
212 620 46 00
I would still VIN check the part numbers.
Old Mar 21, 2018 | 12:57 AM
2015 E 350
Thank you so much!
