Sponsored by: CARiD
Unused Air intake
Old Aug 27, 2018 | 07:24 AM
Eddot's Avatar
2015 S550 Executive, 2017 Volvo XC60 R design, 2009 BMW Z4 35i DCT TwinTurbo
Unused Air intake
Heres an interesting question. On my '14 E350 , the V6 is non turbo and only the passanger side of the engine has the air intake/filter so the drivers side air intake over the radiator area has a cap on the back which blocks any incoming air from the engine compartment. Would there be any advantages or disadvantages to removing this back cover to let some air flow into the engine compartment, for maybe additional cooling.
Old Sep 2, 2018 | 08:03 PM
DFWdude's Avatar
2016 E350 Sport
Does anyone have an answer for this? I think it a good quesiton. I wonder if cars with aftermarket tunes would benefit.
Old Sep 2, 2018 | 08:11 PM
ItalianJoe1's Avatar
2003 CL 600
No. Airflow through the engine bay is carefully controlled, that's why there's a ton of baffles and seals around the radiator and front end, all air coming in goes through the cooling package, then over the engine and down and out the bottom of the car. If you open up more holes in the front of the car, the only thing you do is increase drag. Will be negligible, but it won't have any positive effect.
Old Sep 2, 2018 | 10:46 PM
DFWdude's Avatar
2016 E350 Sport
Thanks ItalianJoe1... your MB service tech experience is very helpful in clearing up the countless questions we dummies seem to have.
Old Sep 3, 2018 | 05:18 AM
Fly.dive.drive's Avatar
W212 E350, UZJ100, PZJ77
agree fully, here’s why
negative air pockets are engineered into all modern cars to essentially induce a vacuum in the engine bay at speed. This serves suck hot air out of the engine. Positive pressure air pockets are located immediately in front of the radiator and (often) at the base of the windscreen. Negative air pockets are controlled by use of baffles and cowls (as mentioned above) to reduce turbulence below the car and recycle air inside the engine bay. Even small changes to these, especially in higher engineered cars will have negative effects. So remember put your skid plates back on and replace/repair broken plastics.
Old Sep 3, 2018 | 06:37 AM
Eddot's Avatar
Thanks for the thoughts, Guys. It seem that someone by now would have come up with an add on intake Y pipe connection to connect this opening to the air box side intake pipe for more air increase volume...more has to be better, right?
Old Sep 3, 2018 | 01:00 PM
Tump43's Avatar
2014 E350 4Matic
+1. I think that make a great product. Any DIY ideas?
Old Sep 4, 2018 | 12:32 PM
happyeds's Avatar
2018 S560
Adding my two bucks. In the newer cars even the pitch of the grill slats are important for air delivery to the intake runners. We have all paid quite dearly for this engineering so keep it in mind before making changes.
