Battery display message won't go out
Battery
Fuel Pump
Crank Sensor
ECT sensor
Rear SAM
CAM sensor magnets ( had issues with misfires)
Spark Plugs
Still issue persists. Any ideas. " No computer codes"
2008 E550
Battery
Fuel Pump
Crank Sensor
ECT sensor
Rear SAM
Spark Plugs
2008 E550
"No computer code"... from what scanner: OBD2-basic or an extended bus?
Crank shaft sensor was a excellent guess
Battery
Fuel Pump
Crank Sensor
ECT sensor
Rear SAM
Spark Plugs
2008 E550
I just replaced my starter. I had a couple long cranks and all cranks were longer than normal. Big improvement with starting with the new starter.
Have you looked or measured you actual main battery voltage right before that happens?
Use the "Worskshop menu" aka. "Secret Menu" to confirm your battery was indeed getting charged above 12.6V before you stopped the engine.
You may find that after driving your car daytime (no headlights) for a while at highway speed, the engine computer commands your alternator to DRAIN your battery below 11.x Volts under high Amps...
Please share your findings, Txs.
