Is a loud engine normal for an E350 Sport?
The thing is that I have a 2012 E350 convertible sport and it is quiet and smooth. Even with the convertible top it’s much quieter and smoother running than the sedan. They claim it’s not possible but it’s true!
I'm thinking about just selling my W212 and just driving the convertible.
Visually its hard to tell their compressed without a reference... even new ones will compress some once you let the weight of the engine down. Besides checking for signs of oil seepage from the mount.
I agree with 👆mine is the same It doesn’t bother me. Kinda like it but, engine mounts need replacing. I took mine to MB to check them and sure enough need new ones plus the tranny needs one. You will lose a lot of power if not replaced.
It seems there are some differing opinions as to what it is.
To help hone in here is a video of the engine noise -> https://youtu.be/oFiVe7dj8Js
What is that?
I bought it used with 60K miles, if that helps.
Damn at 60k that’s too early for mounts to collapse. First owners must of driven that car hard.
Replacing only the transmission mount if all three are bad won’t do much good. In addition if the motor mounts have collapsed the engine will sit too low in the cradle and the drive shaft and the expensive exhaust system will be misaligned which could end up causing more damage.
Problem solved.
What I've learned:
- I am more sensitive to sound than most people. Some other Mercedes owners (including 3 Mercedes mechanics) thought the sound was normal. I knew it was not (and I've owned a Mercedes for only 4 weeks).
- Mercedes cars can, in fact, be almost as quite as Japanese cars in the cabin.
- Where to get my Mercedes fixed. I found an awesome mechanic who was really understanding and fixed the issue for a fraction of the Mercedes dealer's cost.
- These forums are quite helpful. Thanks to everyone for your input!
- @ItalianJoe1 is the man! He was the first to call out the fix and was right on.
Here's video after the new mounts, in case you want to compare to my earlier video
https://youtu.be/yBOReTgst60
You CANNOT assume that the mounts are not leaking / get them inspected regularly by your trusted mechanic.
The rear transmission mount is rubber, like a donut, easy to replace & inexpensive, in relation to the front oil bags.
The 212 front engine bag mounts are expensive, & my Indy Shop Manager said the engine has to be pulled out & up to replace the right one, & he quoted $2100 to replace all 3 mounts.
FYI:
the W210 series has quite simple & inexpensive
rubber mounts at all 3 stations.
the W124 series also has rubber mounts.
I know because my ‘91 300CE & ‘94 E320
(rwd) Wagon had the rubber mounts which were
cheap to replace & lasted for years.
i think over 15 years, I replaced 1set on each vehicle - at a cost of under $500 / FOR BOTH!
Problem solved.
What I've learned:
The 2011-2016 E350 W/S 212 engine mounts are oil-filled bags which deteriorate over time & with wear.
You CANNOT assume that the mounts are not leaking / get them inspected regularly by your trusted mechanic. You CANNOT assume X number of miles before replacing them due to the obvious vibrations & cabin noise.
FYI:
I know because my ‘91 300CE, my ‘94 E320
(rwd) Wagon, AND my ‘01 E320 4Matic Wagon, had the rubber mounts which were
i think over 15 years, I replaced 1set on each vehicle - at a cost of under $500 / FOR ALL!!!
Me: The noise in the cabin sounds pretty loud. Definitely louder than my other cars. Other Mercedes owners [those of you who have responded to this thread] have said it sounds abnormal.
Mechanic: Sounds pretty normal. Nothing to worry about.
Me: You're saying other Mercedes are this loud?
Mechanic: Don't know. I don't have an E350 to compare.
Me (in my head): Then, how can you say its normal?
I suppose I need to try a different mechanic.
BTW - I rode in an E300 yesterday and it was very different - quiet like my prior cars.
I'm definitely not imagining this.
