E350 Rear Rotors & Pads Recommendation
I went close to the Centric route (R1 Concepts) and have had no issues since installation, I also rebuilt the calipers and flushed the fluid.
https://mbworld.org/forums/e-class-w...2011-e350.html
All items Front/Rear Left/Right Unless noted.. All four corners in modern day language.
Slotted Rotors: I ordered the E-Line series but with delay due to not in stock I was given a FREE UPGRADE to the Carbon Geomet Series. The only difference is that the Geomet series protective coating is zinc instead of black.
Ceramic Pads E series
Front and Rear Hardware replacement kit, shims, slide pins, brackets etc...
Brake Pad wear sensors. I thought I ordered four but received eight. Is there one per wheel or Two? (as in Inboard/Outboard)
If you think $1400 is expensive for front AND rear brakes - my MB Service Advisor at the last service quoted AU$1069 just for the rears (about US$1350). I said I would wait until the service indicator flashed up a warning. ECS have a genuine MB rotor, pad & wear sensor kit for about US$200 so I plan on doing my own servicing in future
