Sponsored by: CARiD
Crankcase breather valve for the M276 engine
Old Jun 25, 2019 | 05:12 AM
Oscarvp's Avatar
2012 Mercedes-Benz E350
Exclamation Crankcase breather valve for the M276 engine
Hey guy's, does anyone know or has replace the PCV valve on the M276 Mercedes engine?
Popular Reply
Jun 25, 2019, 11:58 AM
konigstiger's Avatar
konigstiger
'71 Pinto
Centrifuge, as needed:
Oil drip pan (10 in diagram) part # 2730100162
Bolt (20) 000000000281
Seal (40) 2760180080
O-ring (50) 0239970345
Housing (30) 2760100331
Bolt x4 (60) 000000003648
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old Jun 25, 2019 | 11:58 AM
'71 Pinto
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old Aug 2, 2019 | 02:16 AM
Oscarvp's Avatar
THANKS.
Old Aug 22, 2020 | 03:46 PM
StevilKnievel's Avatar
2013 C300 4matic Sport sedan
Outstanding. Do you need to remove the rear cover like on the 272's? Also, can the expansion plugs be replaced with the cover still on?
Old Dec 14, 2020 | 11:42 PM
Knightstale04's Avatar
2012 C250 Coupe
Lightbulb 1.8L 4 -cyl Engine 271.860 Turbo, still have the gas smell in oil
Hello Konigstiger,
Thank you so much for your post and very detailed explanation about the Centrifuge which I though was the crankcase breather or PVC valve. I have a 2012 C250 and the part # 2760100331 centrifuge cover it tells me that is not the correct part for my vehicle. In addition, your repair instructions seem much more complex than what I had believed would not require draining coolant or diving into the crankcase. Is all of that necessary just to replace the centrifuge and it's cover? I know it is in a hard to reach area, but is that whole procedure necessary? I have the 1.8L 4 -cyl Engine 271.860 Turbo
Do you think an issue with the centrifuge could be causing oil to drip down into my oil pan? Thank you sincerely for the awesome detailed instructions, but please let me know how much of those detailed steps are necessary?
Thank you sincerely,
Greg
Last edited by Knightstale04; Dec 14, 2020 at 11:49 PM. Reason: more information about my car
Old Dec 15, 2020 | 08:24 AM
'71 Pinto
Here are engine “breathing” components for your engine to check see attachment for part #s.
File Type: pdf
Old Dec 15, 2020 | 02:23 PM
2012 C250 Coupe
Konigstiger,
I cannot thank you enough for your help with this issue! I tried to have repaired by my local Walnut Creek Mercedes service shop. I took it there for a diagnostic check to find where the strong gas fumes are coming from. They could not find the cause, and only pointed out the strong smell of gas on the dip stick. Then they told me there was nothing they could find as the reason. The car actually runs well and it just passed the smog test for my registration, but there is something causing gas to leak into the oil pan. When I drive on the freeway the fumes are very strong in the cabin and when I park in the garage the fumes are brutal around the car too. There are no visible leaks anywhere and no error codes, and I am only speculating from reading information from Mercedes forums that the issue might be the oil separator, centrifuge, crankcase breather or PCV valve? You seem to be very familiar with these cars, what would you think could be the most likely cause for this issue? Does this engine have the centrifuge and centrifuge cover? If you do think the issue I am having is related to the diagram you provided, which of the listed parts would you recommend replacing? I really love the car and if I could solve the gas fume issue it would be huge! Is it possible over filling the the engine oil level could cause an issue like this? . The car was not being used for the past several months because the pandemic had me working from home, but now I need to start commuting again and need to find a solution ASAP. Again, cannot thank you enough for the help, and super quick response.
Greg
Old Dec 15, 2020 | 02:31 PM
'71 Pinto
If there are no apparent leaks consider visiting a reputable independent shop.
Old Dec 29, 2020 | 04:59 PM
AngelVA's Avatar
2008 ML63
I'm having the darndest time getting the HPFP crash bracket off.
Any advice. While the instructions are good to have, they seem very high level and don't give the real world garage applications that maybe necessary.
Old Jan 19, 2021 | 04:22 PM
Cesar350's Avatar
2015 ML350 W166 and 2006 SLK 350 R171
Hi,
I hope you already fixed your problem, if so maybe this file might help others.
Old Jan 19, 2021 | 06:04 PM
AngelVA's Avatar
2008 ML63
Originally Posted by Cesar350
Hi,
I appreciate the document. My issue is getting the last bolt on the bottom of the crash plate. I just could not get a tool back there and in the right spot.
Old Feb 1, 2021 | 03:53 AM
Andyhsan's Avatar
2014 Mercedes e350
Breather replacement
hi I’m trying to replace the oil drip pan and the housing, do I need to remove the high pressure pump or no need just the cover, thank you
Old Oct 10, 2021 | 01:38 PM
Hamburg666's Avatar
2013 Mercedes E350 4matic
CVV (PVC) 2013 E350 4matic
Hi Konigstiger, I have seen your posts and they are extremely informative. I have a 2013 E350 4matic Flex-fuel. 101K miles. A few days ago oil pressure pushed up the Dipstick creating a geyser of oil. Motor runs smooth, so no hole in piston, nor coolant issue. When I shut down motor and remover oi filler cap I do notice quite a bit of pressure. Cab you confirm that this is most likely the Crankcase Vent Valve, or do you have any other ideas? Thanks again. BTW it is a bear to get at!!! Thanks Benz engineers.
Old Oct 10, 2021 | 04:13 PM
'71 Pinto
Blocked centrifuge ‘can’ cause oil/air to find its way through dip stick.
Old Oct 25, 2021 | 10:34 AM
nc211's Avatar
2020 GLS450 (wife) / 2024 Ford Bronco (mine) / 2014 VW Tiquan (son)
There appears to be oil getting into my intake housing and the shop is pointing to the PCV needing replacement soon (59k miles / 2014). Car has been under my ownership since 22k miles (2017), oil always changed at no more than 7k mile intervals. Car does not see redline very often if at all, it is my highway cruiser. I am also getting that stinky oil burn smell again and they're attributing that smell to this as well. Makes sense to me, and the car has developed sense of hesitation under light acceleration (not the TPS issue this time, reset does not fix it).
Does this all sound like a clogging PCV issue? I've had clogged PCV's in the past and they too had a hesitation with them, but never figured oil could get into the intake tubing from one, but on a scale of 1-10 on wrenching ability, I'm probably a 4 in general, 1 on a MB. I only know what I don't know..
Thanks!
Old Oct 25, 2021 | 12:29 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
+1... combo repair
Originally Posted by nc211
There appears to be oil getting into my intake housing and the shop is pointing to the PCV needing replacement soon (59k miles / 2014). Car has been under my ownership since 22k miles (2017), oil always changed at no more than 7k mile intervals. Car does not see redline very often if at all, it is my highway cruiser. I am also getting that stinky oil burn smell again and they're attributing that smell to this as well. Makes sense to me, and the car has developed sense of hesitation under light acceleration (not the TPS issue this time, reset does not fix it).<br /><br />Does this all sound like a clogging PCV issue? I've had clogged PCV's in the past and they too had a hesitation with them, but never figured oil could get into the intake tubing from one, but on a scale of 1-10 on wrenching ability, I'm probably a 4 in general, 1 on a MB. I only know what I don't know..<br /><br />Thanks!
<br />I think your assessment is 100% correct about the oil consumption and hesitations pointing at failed PCV. <br /><br />I have the same MY'14 with leaking oil smell since day-1. The intake is swamped with PCV oil. Intake valves never see gasoline in this direct injection engine. Cats and O2 sensors get contaminated by burnt oil.<br /><br />It's better to get the PCV upgraded before excessive pressure blows through the heat exchanger skinny gasket. Normally the crankcase is under a slight vacuum to help pistons travel and recycle blowby fumes... Not pressure!<br /><br />​​​​​​While getting your PCV repaired concider getting your <strong>spark plugs</strong> done too! Removing the intake plenum allows to dump all the engine oil out of the intake track.<br /><strong>Reset</strong> the ECU to relearn the idle mixture at once for minimal hesitations.<br /><br />Have you had your secondary chain <strong>tensioners</strong> renewed?
Old Oct 25, 2021 | 12:39 PM
+1... combo PCV + Plugs
Thanks!
​​​​​​While getting your PCV repaired concider getting your spark plugs done too! Removing the intake plenum allows to dump all the engine oil out of the intake track.
Reset the ECU to relearn the idle mixture at once for minimal hesitations.
Have you had your secondary chain tensioners renewed?
Old Oct 25, 2021 | 05:44 PM
chassis's Avatar
2017 GLE350 4MATIC
@CaliBenzDriver Is a WIS or XENTRY document available for the ECU reset?
Old Oct 25, 2021 | 06:00 PM
BenzNinja's Avatar
Former Vendor
just push the button
Old Oct 25, 2021 | 06:31 PM
default mixture
Chassis > I don't know which doc... just unplug any engine electrical (coolant recirculating pump, thermostat, etc) to quickly trigger an ECU error.
Now you can reset the ECU through the scanner DTC Menu (without having read a fault, Reset option stays greyed out)
Without a hard reset... the new mixture adaptation is slowly tuned over a 1,000 miles or more using historical fuel trims records.
If your engine suffers from mild hesitations between deceleration and acceleration, something may be slightly leaning out your fuel trims.
The learned rich/lean mixture map is super sensitive to combustion results.
