Sponsored by: CARiD
Check Engine Light, code P2571
Old Jul 10, 2019 | 07:51 PM
cx876's Avatar
W212, R171
I have a 2011 E350, recently got a check engine light, I scan the car with my handle OBD2 scanner come back as code P2571,
maybe from a sensor in the radiator and seems like an uncommon problem for W212,
one post I found on Benz World mention that it's causing by after market HID kit, which I have, but it's a quality unit from MTEC.
I try reset the code with my scanner, it went away for two weeks and just came back yesterday, so I think the problem is legit.
Meanwhile, car drives perfect, doesn't feel like anything is wrong.
so I want to see anyone has any experience on that, any input will be appreciated.
Old Jul 11, 2019 | 12:51 PM
Sunnyslope48's Avatar
2016 E350 Sport 2WD
Call the manufacturer of the lights and see what they have to say. If anyone has experience with this p-code, it will be them.
Old Jul 16, 2019 | 11:42 PM
Mario_C's Avatar
W204 220cdi
look at the difference between OBD1 and OBD2 scanners in autoguysland website. Autoguysland give some benefits and difference of them
Have you use another scanner tool to check again and see any code ??
Old Jul 17, 2019 | 12:06 PM
2016 E350 Sport 2WD
Old Jul 17, 2019 | 01:50 PM
konigstiger's Avatar
'71 Pinto
Consider having someone pull codes using MB DAS (diagnostics) could be related to exhaust oxygen sensor(s).
FYI temperature sensor referenced is for PZEV vehicles (data card will list code 917):
- 211 PZEV = 2115420918
- 212 PZEV = 2219055600 (350 in diagram)
Old Jul 17, 2019 | 04:59 PM
cx876's Avatar
W212, R171
Hey guys, sorry for the late update, thanks konigstiger, that's the sensor that I originally thinking about.
But here's what happened,
the day after I post this thread (7/11), I drove my car to work, to lunch and back (less than 9 miles total),
and when I pick up my car after work, the CEL is gone as soon as I started the engine, and it haven't comes back till today (knock on wood)
do you guys think I should bring it to the shop nonetheless just in case ? or just the sensor acting funny and I shouldn't worry about it until it light up for the 3rd time ?
Thanks everyone.
Old Oct 29, 2019 | 03:59 PM
jzheng's Avatar
E350
I have the same 2011 E350, and the same check engine problem with P2571.
Sometimes the check engine light would go away by itself, but most of the time, it need to be clear using the OBD reader.
On my most recent smog check (July 2019), the car failed the test due to the permanent code for this problem...The smog check shop owner told me that I need to go to the dealership, and it may still be covered by warranty...
To my surprise, the Mercedes Benz dealership checked and confirmed the problem, and fixed it for free.
You should definitely bring it to the dealership.
Old Oct 30, 2019 | 06:04 PM
cx876's Avatar
W212, R171
oh sweet ! I'm going to get my 90K service done at dealer next month, thanks for the info !
