Sponsored by: CARiD
My E class 350 2014 trouble
Old Aug 25, 2019 | 06:04 PM
Blondelady's Avatar
Merc 350 E clasd
Hi all ,
can u give me some feedback if there is a fault in the e class 350 2014 , coolent and transmission fluid mixing ?? Help please
Old Aug 25, 2019 | 08:11 PM
chassis's Avatar
2017 GLE350 4MATIC
Welcome! Please post a photo of the E350. What are you experiencing? A message on the display? Smoke pouring from under the hood? Does the engine run?
Old Aug 26, 2019 | 12:12 AM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W212 forum...
Old Aug 26, 2019 | 06:02 AM
Blondelady's Avatar
Merc 350 E clasd
2014 merc E class -- coolent problem
I don't have a picture and my car is at merc dealer , as they are speaking yo head office about the problem
the coolest light was on , they added coolest light stayed on
they were going to do a flush but changed their minds
as they believed it was more serious , I called merc head office and auto nation
just wanting yo know if anyone has had a problem like this ??
Old Aug 28, 2019 | 07:05 PM
Money Pit's Avatar
W212 E350
See also transmission failure
Hi,
You might find some other forum members with who may have gone through a similar issue by searching the forum for transmission failures:
https://mbworld.org/forums/e-class-w...n-failure.html
You could also try the "sticky" forum 'Bulletins 207 coupe & 212 sedan' for any MB service bulletins.
Old Aug 28, 2019 | 07:52 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
You speak strange English, but so are lot of us
coolant in transmission has only 1 way to get there >>> failed heat exchanger inside radiator.
So when radiator replacement is easy call, main question is can the transmission be flushed and saved?
Do you have any warranty?
Old Aug 28, 2019 | 09:52 PM
ItalianJoe1's Avatar
2003 CL 600
They have the same problem of the auto transmission cooler leaking as the earlier cars. Usually, glycol contamination of the clutch material in the transmission ruins them, you MAY be able to flush it several times and get no chatter or harsh shifting, but sadly if you do continue to get poor shifting, the only fix is a replacement of ALL the frictions in the trans.
