Bad Engine Noise Upon Starting
What the heck was that? I have not hooked up STAR, as there is no current obvious problem.
I am currently dealing with this issue and did the TSB however I am still getting the noise. My issue now is a failed camshaft adjuster which should always keep pressure but with age it has failed and after I start my engine which sat for 2 hrs or more, I get this rattle sound. Its becoming more and more common on M276 , M278 and M157 as they all use the same part.
Tensioners and valves, cost me ~ $275 and my labor, however one camshaft adjuster from MB is appox ~$700(there are 4), and the job on M276 is about 6hrs of labor(unless you take a shortcut and dont remove valve covers)
Thank you so much for chiming in! I am dealing with exactly the same problem. I also did the TSB Ll05.10-p-056435 and much to my dismay; still have the rattling when the oil pressure drops down after sitting for some time, in my case one hour or less. I even re-opened both front covers to check to see if there was something holding up the tensioners to allow the oil to drain back. Everything appeared to be okay. I am getting a fault codes P034600 & P002177 "Position of intake camshaft Bank2 deviates from specific value, the commanded position cannot be reached". Exactly as you said, the cam adjuster Bank2 seems to have failed on my engine.
I have to do some more research. I saw in another post that there is a test routine in SDS for the cam adjusters. That will be my next step when I get time to find and carry out those tests on my SDS.
I am not sure if my skill set is up to playing around with this repair, how about you??
Thanks again for posting……
Bob
Bob
I am extremely disappointed in MB engineering as others have stated. I love the idea of driving an MB but understand that BMW and Audi have their issues too.
Keep us informed of your final solution.
Good luck,
Bob
Good luck,
Bob
I am having the same issue as many of you all did with the rattle sound from the cam adjusters (see video attached). I took the car in to the dealer so they could tell me what exactly am I looking at to fix it and boy let me tell you, it's a pretty penny (outlined further below). I mean of course at this point for all their suggested work it doesn't make sense with the value of our cars. The interesting part here is my dealer told me we are going to need to replace the cam as well which I notice wasn't mentioned in the earlier posts, is that something you all went through as well? What was some of the resolution you all had on this?
- Mehroz
- Mehroz
single parts quantities ...
1 VVT adjuster and 1 camshaft... how about the other 3 units??
Were they not damaged from the low oil pressure leaking through the tensioner??
Regardless... all good, after ~15k kms and counting.
They should be able to show you the out-of-spec reading, or provide better explanation why the camshaft needs replacing.
